#mysql -V
mysql Ver 15.1 Distrib 5.5.60-MariaDB, for Linux (x86_64) using readline 5.1
MariaDB [nagiosql]> SELECT @@SQL_MODE, @@GLOBAL.SQL_MODE\G;
*************************** 1. row ***************************
@@SQL_MODE:
@@GLOBAL.SQL_MODE:
1 row in set (0.00 sec)
ERROR: No query specified
I have sent a PM with the httpd error log and Mariadb.log please have a look.
Hosts and services disappears for a while
Re: Hosts and services disappears for a while
Currently we have one server running wit 5.5.11, but i don't see such an issue for a user where hosts/services disappear.
benjaminsmith
Hi @ISSB_MAOST,
After looking through the database log, it looks like you have setup database replication, and it's having issues. Can you repair the replication?190517 3:46:18 [ERROR] Slave SQL: Could not execute Write_rows event on table nagios.nagios_servicestatus; Duplicate entry '18665' for key 'object_id', Error_code: 1062; handler error HA_ERR_FOUND_DUPP_KEY; the event's master log mariadb-bin.000002, end_log_pos 55291742, Error_code: 1062
190517 3:46:18 [Warning] Slave: Duplicate entry '18665' for key 'object_id' Error_code: 1062
190517 3:46:18 [ERROR] Error running query, slave SQL thread aborted. Fix the problem, and restart the slave SQL thread with "SLAVE START". We stopped at log 'mariadb-bin.000002' position 55291130
HI, i reapired the replication and tried, but seeing the hosts& services disappear. i sent you a PM of mariadb.log please have a look
benjaminsmith
Hi @ISSB_MAOST,
Are you able to generate a system profile yet? Looking at your log files, your still having issues with the database replication.
190517 11:52:38 [ERROR] Failed to open the relay log './mariadb-relay-bin.000008' (relay_log_pos 3414121)
190517 11:52:38 [ERROR] Could not find target log during relay log initialization
190517 11:52:38 [ERROR] Failed to initialize the master info structure
I have disabled replication and wiped out replication completely. and tested again but still no luck and am not able to download profile.
benjaminsmith
The following command will check for corrupted tables. If it doesn't output anything, the tables are ok.
If you have any crashed tables, the following will repair the databases.
If the issue persists, please open a support ticket at the link below and reference this thread as we may need to take a closer look at your system.
https://support.nagios.com/tickets/
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table | grep NULL
mysqlcheck -r -f -uroot -pnagiosxi --all-databases --use_frm
