NagiosXI 5.6.2 Switch/Router wizard and Cisco 4000 series
dfmco
Re: NagiosXI 5.6.2 Switch/Router wizard and Cisco 4000 serie
Post by dfmco »
Changes made. No change on manual or gui checks. They both still fail.
We have another system whose permissions are the same as this one was before the change and it works fine (root:nagios).
[root@wctcog-jones-netmon-pri mibs]# su nagios
[nagios@wctcog-jones-netmon-pri mibs]$ /usr/local/nagios/libexec/check_ifoperstatnag 2 -v3 -u nms -A "EdiS2019" -x AES -X "Cordoba2019" -a SHA -l authPriv 172.16.115.1
/usr/share/snmp/mibs/HOST-RESOURCES-MIB.txt: Permission denied
MIB search path: /home/nagios/.snmp/mibs:/usr/share/snmp/mibs
Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
/usr/share/snmp/mibs/HOST-RESOURCES-TYPES.txt: Permission denied
Cannot find module (HOST-RESOURCES-TYPES): At line 0 in (none)
/usr/share/snmp/mibs/UCD-DISKIO-MIB.txt: Permission denied
Cannot find module (UCD-DISKIO-MIB): At line 0 in (none)
/usr/share/snmp/mibs/TCP-MIB.txt: Permission denied
Cannot find module (TCP-MIB): At line 0 in (none)
/usr/share/snmp/mibs/UDP-MIB.txt: Permission denied
Cannot find module (UDP-MIB): At line 0 in (none)
/usr/share/snmp/mibs/MTA-MIB.txt: Permission denied
Cannot find module (MTA-MIB): At line 0 in (none)
/usr/share/snmp/mibs/NETWORK-SERVICES-MIB.txt: Permission denied
Cannot find module (NETWORK-SERVICES-MIB): At line 0 in (none)
/usr/share/snmp/mibs/SCTP-MIB.txt: Permission denied
<SNIP>
Here are the permissions of a working 5.5.11 install at another location:
[root@txoma-cooke-netmon-pri ~]# ls -al /usr/share/snmp/mibs
total 2236
drwxrwsr-x. 2 root nagios 4096 Dec 6 11:48 .
drwxr-xr-x. 5 root root 4096 Dec 6 11:48 ..
-rw-rw-r-- 1 root nagios 17455 Oct 30 2018 AGENTX-MIB.txt
-rw-rw-r--. 1 root nagios 37659 Jul 4 2014 BGP4-MIB.my.txt
-rw-rw-r-- 1 root nagios 50948 Oct 30 2018 BRIDGE-MIB.txt
-rw-rw-r--. 1 root nagios 80063 Jul 3 2014 CISCO-BGP4-MIB.my.txt
-rw-rw-r--. 1 root nagios 36493 Jul 3 2014 CISCO-CONFIG-MAN-MIB.my.txt
-rw-rw-r--. 1 root nagios 47872 Jul 3 2014 CISCO-EIGRP-MIB.my.txt
-rw-rw-r--. 1 root nagios 36418 Jul 3 2014 CISCO-ENVMON-MIB.my.txt
looks the same as this 5.6.2 install before I made the change.
Please run these commands as root on the system that is having the issue and upload the /tmp/info.txt file to the forum post.
chage -l nagios >/tmp/info.txt
grep nag /etc/group >>/tmp/info.txt
ls -l /usr/share >>/tmp/info.txt
ls -l /usr/share/snmp >>/tmp/info.txt
ls -l /usr/share/snmp/mibs >>/tmp/info.txt
ls -l /usr/local/nagios/libexec >>/tmp/info.txt
dfmco
Post by dfmco »
Log of the following commands attached:
The directory permissions for the mibs folder is incorrect, run this as root to fix it.
chmod ugo+x /usr/share/snmp/mibs
Then run the check again to see if the error messages are gone and the plugin runs.
dfmco
Post by dfmco »
That fixed the issue. Is this a known issue as I have to upgrade the backup server from 5.5.11 to 5.6.2.
Thanks!
benjaminsmith
Post by benjaminsmith »
Hi @dfmco,
Glad to hear it has been resolved. The current upgrade script in Nagios Xi will set the correct permissions for the folder.
dfmco
Post by dfmco »
Thanks!
benjaminsmith
Your welcome!
I'll go ahead and lock this one up, but feel free to open a new post if you have any questions.
Have a great weekend, and thank your for using Naigos.
