1. What do the permission look like on the folder and the files in there? These are the permissions on my lab machine:
drwxrwxr-x 2 nagios nagios 74 Jul 3 11:46 .
drwxrwxr-x 3 nagios nagios 19 Jul 2 10:26 ..
-rw-rw-r-- 1 apache apache 592 Jul 2 11:53 000_inputs.conf
-rw-rw-r-- 1 apache apache 1.1K Jul 2 11:53 500_filters.conf
-rw-rw-r-- 1 apache apache 390 Jul 2 11:53 999_outputs.conf
2. Through the GUI.
If the above doesn't help resolve the issue, please try saving and applying the changes again and then gather a profile from the system. It can be gathered under Admin > System > System Status > Download System Profile or from the command line with:
/usr/local/nagioslogserver/scripts/profile.sh
This will create /tmp/system-profile.tar.gz.
Please PM me the file but note that this file can be very large and may not be able to be uploaded. This is usually due to the logs in the logstash and/or elasticseach directories found in it. If it is too large, please open the profile, extract these directories/files and send them separately.
