Next Scheduled Check over the Time Period
cdienger
Re: Next Scheduled Check over the Time Period
Post by cdienger »
The information is stored in the status.dat and can be changed via external command: https://assets.nagios.com/downloads/nag ... and_id=129
antoniosc
Post by antoniosc »
cdienger wrote:The information is stored in the status.dat and can be changed via external command: https://assets.nagios.com/downloads/nag ... and_id=129
Thanks! Very useful and just what I was looking for!
In meanwhile, we're applying the Fix #647 reported on GitHub: https://github.com/NagiosEnterprises/na ... e/pull/649
Last question, is it possible to subscribe/set an alert when the new NagiorCore v4.4.4 will be released?
antoniosc wrote:Last question, is it possible to subscribe/set an alert when the new NagiorCore v4.4.4 will be released?
If you go to
https://github.com/NagiosEnterprises/nagioscore/
and star the project (upper right) you should get a notice from Github when it is released
