It would be better to just re-run the upgrade and choose yes to allow it to modify the sudoersdaviddief wrote:Yep, you got it. I forgot to tweak the /etc/wgetrc file and now it is able to finish. Last step is to 'Copy new sudo permissions from './nagiosxi/nagiosxi.sudoers' to the /etc/sudoers file'. Is there a simple one-liner command for that? I am an idiot with Linux so I try not to get too adventurous.
Error during upgrade from 5.5.9 to 5.6.2
