Please note, XXX denotes the redacted name of the affected server, YYY denotes other servers. I hope this isn't too confusing, I'd rather keep my company's server names a secret.2019-06-05 16:33:43 [14267] [2] RRDs Perl Modules are not installed. Falling back to rrdtool system call.
2019-06-05 16:33:43 [14267] [2] /usr/bin/rrdtool update /usr/local/nagios/share/perfdata/YYY/Alive.rrd 1559745209:0.241:0:0.385:0.193
2019-06-05 16:33:43 [14267] [1] rrdtool update returns 0
2019-06-05 16:33:43 [14267] [2] Processing Line 620
2019-06-05 16:33:43 [14267] [2] Datatype set to 'SERVICEPERFDATA'
2019-06-05 16:33:43 [14267] [1] Found Performance Data for XXX / Memory_Usage ('Memory usage'=75668.72MB;96666.07;108749.33;0.00;120832.59)
2019-06-05 16:33:43 [14267] [2] No Custom Template found for check_xi_service_nsclient (/usr/local/nagios/etc/pnp/check_commands/check_xi_service_nsclient.cfg)
2019-06-05 16:33:43 [14267] [2] Template is check_xi_service_nsclient.php
2019-06-05 16:33:43 [14267] [2] data2rrd called
2019-06-05 16:33:43 [14267] [2] /usr/bin/rrdtool update /usr/local/nagios/share/perfdata/XXX/Memory_Usage.rrd 1559745209:75668.72
2019-06-05 16:33:43 [14267] [2] Processing Line 621
2019-06-05 16:33:43 [14267] [1] Found Performance Data for YYY / SWAP (swap=2047MB;1228;0;0;2047)
2019-06-05 16:33:43 [14267] [2] No Custom Template found for check_nrpe (/usr/local/nagios/etc/pnp/check_commands/check_nrpe.cfg)
2019-06-05 16:34:34 [20406] [1] rrdtool update returns 0
2019-06-05 16:34:34 [20407] [2] Template is check-host-alive.php
2019-06-05 16:34:34 [20407] [2] data2rrd called
2019-06-05 16:34:34 [20406] [2] Processing Line 23
2019-06-05 16:34:34 [20406] [2] Datatype set to 'SERVICEPERFDATA'
2019-06-05 16:34:34 [20406] [1] Found Performance Data for XXX / Drive_D__Disk_Usage ('D:\ Used Space'=188.09Gb;319.50;337.25;0.00;355.00)
2019-06-05 16:34:34 [20406] [2] No Custom Template found for check_xi_service_nsclient (/usr/local/nagios/etc/pnp/check_commands/check_xi_service_nsclient.cfg)
2019-06-05 16:34:34 [20406] [2] Template is check_xi_service_nsclient.php
2019-06-05 16:34:34 [20407] [2] RRDs Perl Modules are not installed. Falling back to rrdtool system call.
2019-06-05 16:34:34 [20406] [2] data2rrd called
2019-06-05 16:34:34 [20407] [2] /usr/bin/rrdtool update /usr/local/nagios/share/perfdata/YYY/_HOST_.rrd 1559745258:10.451:0:15.375:9.196
2019-06-05 16:34:34 [20406] [2] RRDs Perl Modules are not installed. Falling back to rrdtool system call.
2019-06-05 16:34:34 [20406] [2] /usr/bin/rrdtool update /usr/local/nagios/share/perfdata/XXX/Drive_D__Disk_Usage.rrd 1559745241:188.09
2019-06-05 16:34:34 [20404] [1] rrdtool update returns 0
2019-06-05 16:34:34 [20404] [2] Processing Line 22
2019-06-05 16:34:34 [20404] [2] Datatype set to 'HOSTPERFDATA'
2019-06-05 16:34:34 [20404] [1] Found Performance Data for YYY / _HOST_ (rta=30.155ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=35.871ms;;;; rtmin=27.690ms;;;;)
2019-06-05 16:34:34 [20404] [2] No Custom Template found for check_xi_host_ping (/usr/local/nagios/etc/pnp/check_commands/check_xi_host_ping.cfg)
2019-06-05 16:35:42 [29115] [2] RRDs Perl Modules are not installed. Falling back to rrdtool system call.
2019-06-05 16:35:42 [29115] [2] /usr/bin/rrdtool update /usr/local/nagios/share/perfdata/YYY/Gi0_21_link_do_YYY.rrd 1559745319:0.00:0.00:398.86:2401.28:104114958541:650273480918
2019-06-05 16:35:42 [29115] [1] rrdtool update returns 0
2019-06-05 16:35:42 [29115] [2] Processing Line 182
2019-06-05 16:35:42 [29115] [2] Datatype set to 'SERVICEPERFDATA'
2019-06-05 16:35:42 [29115] [1] Found Performance Data for XXX / CPU_Usage ('5 min avg Load'=2%;80;90;0;100)
2019-06-05 16:35:42 [29115] [2] No Custom Template found for check_xi_service_nsclient (/usr/local/nagios/etc/pnp/check_commands/check_xi_service_nsclient.cfg)
2019-06-05 16:35:42 [29115] [2] Template is check_xi_service_nsclient.php
2019-06-05 16:35:42 [29115] [2] data2rrd called
2019-06-05 16:35:42 [29115] [2] /usr/bin/rrdtool update /usr/local/nagios/share/perfdata/XXX/CPU_Usage.rrd 1559745319:2
2019-06-05 16:35:42 [29115] [2] Processing Line 183
2019-06-05 16:35:42 [29115] [1] Found Performance Data for YYY / PING (rta=8.841ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=9.012ms;;;; rtmin=8.778ms;;;;)
2019-06-05 16:35:42 [29115] [2] No Custom Template found for check-host-alive (/usr/local/nagios/etc/pnp/check_commands/check-host-alive.cfg)
2019-06-05 16:36:00 [31082] [2] RRDs Perl Modules are not installed. Falling back to rrdtool system call.
2019-06-05 16:36:00 [31082] [2] /usr/bin/rrdtool update /usr/local/nagios/share/perfdata/YYY/c424-a003.rrd 1559745339:14.348000:0
2019-06-05 16:36:00 [31082] [1] rrdtool update returns 0
2019-06-05 16:36:00 [31082] [2] Processing Line 408
2019-06-05 16:36:00 [31082] [2] Datatype set to 'SERVICEPERFDATA'
2019-06-05 16:36:00 [31082] [1] Found Performance Data for XXX / Service_running__BI_Servers (time=0.000217s;;;0.000000;10.000000)
2019-06-05 16:36:00 [31082] [2] No Custom Template found for check_xi_service_tcp (/usr/local/nagios/etc/pnp/check_commands/check_xi_service_tcp.cfg)
2019-06-05 16:36:00 [31082] [2] Template is check_xi_service_tcp.php
2019-06-05 16:36:00 [31082] [2] data2rrd called
2019-06-05 16:36:00 [31082] [2] /usr/bin/rrdtool update /usr/local/nagios/share/perfdata/XXX/Service_running__BI_Servers.rrd 1559745339:0.000217
2019-06-05 16:36:00 [31082] [2] Processing Line 409
2019-06-05 16:36:00 [31082] [1] Found Performance Data for YYY / Orange_BVPN_LTE_-_10.121.45.1 (rta=51.967999ms;3000.000000;5000.000000;0.000000 pl=0%;80;100;0)
2019-06-05 16:36:00 [31082] [2] No Custom Template found for check-spec-host (/usr/local/nagios/etc/pnp/check_commands/check-spec-host.cfg)
Performance graphs not showing for a specific user
Re: Performance graphs not showing for a specific user
Are you sure XXX is the same host you displayed here
https://support.nagios.com/forum/viewto ... 29#p284404
The service names don't match the list you showed with the permissions output.
I took a good look at the performance data directories and renamed the affected server's directory to reflect its current name (seems like it didn't change after the host was renamed in XI). This started up graph generation, fixing the issue. Thank you for your support @scottwilkerson, I wouldn't be able to fix this without your tips.
Glad it is resolved!IkaIka wrote:I took a good look at the performance data directories and renamed the affected server's directory to reflect its current name (seems like it didn't change after the host was renamed in XI). This started up graph generation, fixing the issue. Thank you for your support @scottwilkerson, I wouldn't be able to fix this without your tips.
