tail -f /var/log/httpd/*error*Code: Select all
tail -f /var/log/httpd/*error*==> /var/log/httpd/error_log <==
[Wed Jun 05 10:29:47 2019] [error] [client 172.27.114.52] PHP Notice: Call made to exac_sql_query() when DB handler does not exist\n#0 exec_sql_query(nagiosxi, SELECT * FROM xi_options WHERE name='wc_display', ) called at [/usr/local/nagiosxi/html/includes/utils.inc.php:1033]\n#1 get_option(wc_display, 0) called at [/usr/local/nagiosxi/html/includes/components/capacityplanning/includes/capacityreport.js.php:187]\n in /usr/local/nagiosxi/html/includes/db.inc.php on line 511, referer: http://10.161.176.67/nagiosxi/includes/ ... anning.php
[Wed Jun 05 10:30:11 2019] [error] [client 172.27.114.52] PHP Notice: Call made to exac_sql_query() when DB handler does not exist\n#0 exec_sql_query(nagiosxi, SELECT * FROM xi_options WHERE name='wc_display', ) called at [/usr/local/nagiosxi/html/includes/utils.inc.php:1033]\n#1 get_option(wc_display, 0) called at [/usr/local/nagiosxi/html/includes/components/capacityplanning/includes/capacityreport.js.php:187]\n in /usr/local/nagiosxi/html/includes/db.inc.php on line 511, referer: http://10.161.176.67/nagiosxi/includes/ ... s&manual=1
Loading pages (1/6)
[Wed Jun 05 10:30:46 2019] [error] [client 127.0.0.1] PHP Notice: Call made to exac_sql_query() when DB handler does not exist\n#0 exec_sql_query(nagiosxi, SELECT * FROM xi_options WHERE name='wc_display', ) called at [/usr/local/nagiosxi/html/includes/utils.inc.php:1033]\n#1 get_option(wc_display, 0) called at [/usr/local/nagiosxi/html/includes/components/capacityplanning/includes/capacityreport.js.php:187]\n in /usr/local/nagiosxi/html/includes/db.inc.php on line 511, referer: http://localhost/nagiosxi/includes/comp ... r_compat=1
=================================================> ] 88%
==> /var/log/httpd/ssl_error_log <==
[Wed Jun 05 10:37:53 2019] [error] [client 10.161.156.25] File does not exist: /usr/local/nagiosxi/html/includes/js/jquery/jquery-1.11.2.min.js, referer: https://monitor.noviscorp.cl/
[Wed Jun 05 10:38:05 2019] [error] [client 172.27.200.29] File does not exist: /usr/local/nagiosxi/html/includes/js/jquery/jquery-1.11.2.min.js, referer: http://nagios.servicio.novis.com/
It is possible that you are hitting a limit with the php max_execution_time if you are hitting the limit when trying to run a report over a whole hostgroup because it takes quite some time to create the capacity planning report in general, but with the PDF report there isn't a page limit so it could be creating TONS of graphs, and this will take a lot of timenovisnagios wrote:When generating individual reports of the servers these are generated without problems, but when generating a report of some hostgroup or several servers in only one, the PDF conversion ends with errors. There is some solution.
This change was already suggested in another comment, which does not work.scottwilkerson wrote:It is possible that you are hitting a limit with the php max_execution_time if you are hitting the limit when trying to run a report over a whole hostgroup because it takes quite some time to create the capacity planning report in general, but with the PDF report there isn't a page limit so it could be creating TONS of graphs, and this will take a lot of timenovisnagios wrote:When generating individual reports of the servers these are generated without problems, but when generating a report of some hostgroup or several servers in only one, the PDF conversion ends with errors. There is some solution.
tail -f /var/log/httpd/error_logscottwilkerson wrote:Does it load in the page but not in the PDF report, or not in the page either?
Can you run the followingthen try to send the report and send back all the output from the outputted loggingCode: Select all
Also, 5.6.3 came out this morning that I know is supposed to fix one of the notices you were getting in your logs before.
rpm -qa | grep wkhtmltoxCode: Select all
touch /usr/local/nagiosxi/var/wkhtmltox.log
chmod 777 /usr/local/nagiosxi/var/wkhtmltox.logCode: Select all
tail -f /usr/local/nagiosxi/var/wkhtmltox.log[root@nvsplmonnagvt01 ~]# rpm -qa | grep wkhtmltoxnpolovenko wrote:@novisnagios, What's the output of:Code: Select all
npolovenko wrote:Also, please run the following commands:Code: Select all
touch /usr/local/nagiosxi/var/wkhtmltox.log chmod 777 /usr/local/nagiosxi/var/wkhtmltox.log
[root@nvsplmonnagvt01 ~]# touch /usr/local/nagiosxi/var/wkhtmltox.lognpolovenko wrote:Then tail the wkhtmltox.log and leave the command running:Code: Select all
in the GUI it stays loading and does not end, it does not indicate any message. After a long time I must kill the process to release my session.npolovenko wrote:Open the web interface and generate a PDF report for a host group or multiple hosts. When you see an error in the GUI, take a look at the tail command and copy-paste all errors that it produced.
service httpd restart
