Need plugin for check on log-file
welbp00
Re: Need plugin for check on log-file
Post by welbp00 »
scottwilkerson wrote:Looks like you are missing a - on each argument
./check_logfiles --logfile=/tmp/testlog --criticalpattern 'FAILURE'
Makes no difference:
-bash-4.2# ./check_logfiles --logfile=/tmp/testlog --warningpattern 'FAILURE'
OK - no errors or warnings|'default_lines'=0 'default_warnings'=0 'default_criticals'=0 'default_unknowns'=0
-bash-4.2# ./check_logfiles --logfile=/tmp/testlog --criticalpattern 'FAILURE'
I tried this like you did but could not make it work either.
You will likely want to reach out to the plugin author (we are not the authors of this plugin)
