Email Response Command - missing hash data
Re: Email Response Command - missing hash data
Alright, I've attached the file that needs to be updated. You unzip and place this file in:
/usr/local/nagiosxi/html/includes/components/xicore
You should make sure to rename xicore.inc.php to xicore.inc.php.old before you update the file just in case.
MediaworksNZ
Thanks for the File.
I can confirm that by replying with the below email response works:
I'm still getting the response of "Could not submit command due to missing hash data. Did you reply with the full email?" when I submit:
Any thoughts on this?
ack, downtime
now - 17:00
Someone knocked the plug out!Code: Select all
delay
1 hourThanks
The behavior seen with the delay command will occur if a host isn't in the body of the email. Do you see this all the time? The last log showed this to be successful. If you're able to reproduce it, please do so and provide a fresh log as well as a copy of the email.
MediaworksNZ
I have now put the new server in semi production.
Users are now getting alerts and are wanting to reply via Email.
Lets see if there are any user who are getting the Missing Hash Data in their replies.
Now that it is being used by users, we have noticed that if a user has a signature, the reply to ACK fails.
Is there a solution that can prevent nagios from processing their signatures or is this just one of those scenarios where they have to remove it before sending the reply?
Or is there a way to force all users in Nagios to have emails sent in plain text only?
Is there anything special about the signatures? Images, fonts, anything but text, etc... ? I've been testing with a signature but haven't been able to reproduce.
MediaworksNZ
Yea,
I have tested on my end with a signature and I can't reproduce as well.
User must have typed in the response incorrectly.
On a Separate note, I'm still getting bounce backs from random services when responding via email.
It does not matter what response I use.
Some services will be actioned and others will not and I get the email sent back to me.
I have tested this on a newly created monitored host and also ones that were imported from an old nagios setup.
Subject: Nagios XI - Response Error
- Nagios XI SystemThanks
You are responding above the Respond above this line section, correct? That needs to be included as the hash is hidden in the message.
That's the only way that can happen IMO.
Try running this command before submitting (and leave it running):
Then once it fails again send me the full output of the still run tail command above.
Thank you!
tail -F /var/log/httpd/error_log /var/log/httpd/ssl_error_log /usr/local/nagiosxi/var/cmdsubsys.log /usr/local/nagiosxi/var/eventman.logThank you!
MediaworksNZ
I think this is the issue:
My email templates are set as:
When I remove the actionable examples from the reply email (tested this quickly over the weekend), the service that was failing to be actioned with Hash Data gets actioned.
I have now edited the template to be like this and hoping it will work as I need examples for users to reference.
It must be that the actionable examples were being read due to not having some other characters in front to prevent it from being interpreted as a command?
How would you suggest (i.e supported comments characters) doing this?
***** Nagios XI Alert *****
%alertsummary%
Notification Type: %type%
Host: %host%
State: %hoststate%
Address: %hostaddress%
Info: %hostoutput%
Date/Time: %datetime%
Respond: %responseurl%
Nagios URL: %xiserverurl%
***** Email Response example1: *****
ack or acknowledge (choose one)
I'm looking into this right now (Optional Comments for acknowledgement)
***** Email Response example2: *****
down or downtime (choose one)
9:40 – 10:40 / now - 11:30 (two examples: specify time range)
***** Email Response example3: *****
delay (Delay the next time Nagios XI sends notifications for the object)
5 hour (Must be specified)
In Case of Error:
If the system cannot read a response email you will receive an email back with an error message. Otherwise, it will pass the command onto the subsystem.
*******************************************************************************************************************************************************Code: Select all
%alertsummary%
Host: %host%
State: %hoststate%
Info: %hostoutput%
%alertsummary%
Host: %host%
State: %hoststate%
Info: %hostoutput%
***** ack or acknowledge (choose one) *****
***** I'm looking into this right now (Optional Comments for acknowledgement) *****
***** down or downtime (choose one) *****
***** 9:40 – 10:40 / now - 11:30 (two examples: specify time range) *****
***** Someone knocked the plug out! *****
***** delay (Delay the next time Nagios XI sends notifications for the object) *****
***** 5 hour (Must be specified) *****
In Case of Error:
*******************************************************************************************************************************************************Re: Email Response Command - missing hash data
Good catch! Thank you for posting your templates! I'll report this to the devs and take a look for a workaround (I'm labbing it up, if you don't hear from me by midday tomorrow, please post so that it pops up on our dashboard).
As this functionality was just released we'll need to work through these edge cases.
MediaworksNZ
