sorry for the late reply.
I've have not been able to test yet. I hope to be able to do it this week. We are releasing a new product so I haven't had the time. I will before the end of the week.
Linux SNMP Memory Check - Reported Memory is incorrect
Re: Linux SNMP Memory Check - Reported Memory is incorrect
Noted. We will keep the thread open.
Still didn't work. I'm going to have to build a clean server for this test. Sorry its taken so long.
No problem.Still didn't work. I'm going to have to build a clean server for this test. Sorry its taken so long.
I finally got to test this morning on a new clean install of 5.6.5.
I downloaded the latest wizard and placed it in /usr/local/nagiosxi/html/includes/configwizards. I moved the original linux_snmp dir to my home dir. If I use any linux_snmp wizard it fails with configuration verification failed.
After the failure I deleted the host and added the host again. I used the generic ip wizard and that worked. If I use any snmp wizard it is failing. I tried router/switch, snmp, and snmpwalk and they all fail with the same message.
I thought the snmpwalk wizard would work for sure since its a clean centos 7 minimal installation.
snmp responds from the nagiosxi command line to the server I built. Where do I need to start troubleshooting this problem? Do I need to rebuild this server or is something missing?
Error: Template 'xiwizard_linuxsnmp_mem' specified in service definition could not be not found (config file '/usr/local/nagios/etc/services/192.168.84.58.cfg', starting on line 16)
Nagios Core 4.4.3
Last Modified: 2019-01-15
License: GPL
Reading configuration data...
Read main config file okay...
directives and data definitions. If you are upgrading from a previous
Nagios Core 4.4.3
License: GPL
# Services configuration file
# Created by: Nagios CCM 3.0.3
# Date: 2019-07-22 08:13:10
# Version: Nagios Core 4.x
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
host_name 192.168.84.58
service_description / Disk Usage
use xiwizard_linuxsnmp_mem
check_command check_xi_service_snmp_linux_storage! -C public --v2c -m "^/$" -w 80 -c 95 -f
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard linux_snmp
register 1
service_description collectd
use xiwizard_linuxsnmp_process
check_command check_xi_service_snmp_linux_process! -C public --v2c -r -n collectd
check_interval 5
retry_interval 1
register 1
service_description CPU Usage
use xiwizard_linuxsnmp_load
check_command check_xi_service_snmp_linux_load! -C public --v2c -w 80 -c 90 -f
check_interval 5
retry_interval 1
register 1
service_description ifAdminStatus.1
use xiwizard_snmp_service
check_command check_xi_service_snmp! -p 161 -o 'ifAdminStatus.1' -C 'public' -P 2c -m IF-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description Memory Usage
use xiwizard_linuxsnmp_storage
check_command check_xi_service_snmp_linux_mem! -C public --v2c -w 80,80 -c 90,80
check_interval 5
retry_interval 1
register 1
service_description Ping
use xiwizard_switch_ping_service
check_interval 5
retry_interval 1
_xiwizard switch
register 1
service_description Port 2 Bandwidth
use xiwizard_switch_port_bandwidth_service
check_command check_xi_service_mrtgtraf!192.168.84.58_2.rrd!500.0,500.0!800.0,800.0!M
check_interval 5
retry_interval 1
_xiwizard switch
register 1
service_description Port 2 Status
use xiwizard_switch_port_status_service
check_command check_xi_service_ifoperstatus!public!2!-v 2 -p 161
check_interval 5
retry_interval 1
_xiwizard switch
register 1
service_description Uptime
check_command check_xi_service_snmp! -o 'sysUpTime.0' -C 'public' -P 2c
check_interval 5
retry_interval 1
_xiwizard snmp
register 1
# END OF FILE
check_interval 5
retry_interval 1
register 1
check_interval 5
retry_interval 1
register 1
check_interval 5
retry_interval 1
register 1
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
check_interval 5
retry_interval 1
register 1
check_interval 5
retry_interval 1
_xiwizard switch
register 1
check_interval 5
retry_interval 1
_xiwizard switch
register 1
check_interval 5
retry_interval 1
_xiwizard switch
register 1
check_interval 5
retry_interval 1
_xiwizard snmp
register 1
# END OF FILE
Please download the zip and go to Admin > Manage Config Wizards:
- Click the Browse button and select the zip
- Click the Upload & Install button
You need to do it that way so it puts the proper commands/templates in place.
I did the update via the gui and it worked. That was the piece I was missing. I didn't read the doc as well as I thought.
I modified the defaults in linuxsnmp.cfg and now it works like I wanted.
Sorry for all the delays. Thank you for your help. It's ok to close the thread now.
Great!dslaughter wrote:I did the update via the gui and it worked. That was the piece I was missing. I didn't read the doc as well as I thought.
Locking
