Turning on ldap debug doesnt give desired output.
cdienger
Re: Turning on ldap debug doesnt give desired output.
Post by cdienger »
I was able to reproduce the behavior and it appears to be a bug. I would suggest spinning up a current version of XI, verify this functionality works in your environment, an then perform an upgrade to take advantage of this fix.
https://assets.nagios.com/downloads/nag ... ctions.pdf
bcoleman310
Post by bcoleman310 »
We dont have the luxury of doing that unfortunately. We have to live with the version we have.
Is there a bit of code that can be changed to make it work? I know that is asking a lot.
B
benjaminsmith
Post by benjaminsmith »
Hello @bcoleman,
If a bug is fixed in the current version, we don't provide patches from development for older releases.
If you need to upgrade your license, please contact [email protected].
Let us know if you have any other questions or if we may close out this post. Thank you.
