I made changes as you suggested Please see PM, i sent all configurations i made.
Service in not visible in CCM
Re: Service in not visible in CCM
Did you mean this for a different post?ISSB_MAOST wrote:I made changes as you suggested Please see PM, i sent all configurations i made.
My previous response
As such, it isn't a problem with your configs, it is not possible for someone to see these configs after being applied without making them an admin unless you grant the user "Can see all hosts and services" permissions.scottwilkerson wrote:I want to start by saying I'm sorry the initial test of your findings was done incorrectly, and the tester thought you has a host also assigned to the service (not just a hostgroup).
After re-confirming what you found with the lead architect, it is expected behavior, and there is not a way to work around it without adding the contact to a host and adding that host directly to the configuration created.
With the "limited" view that was added to the CCM, we have to make some sacrifices because there is no way to add permissions for a contact to a hostgroup or service group, only to the hosts or services.
The only way to allow someone to see these configs after being applied without making them an admin would be to grant the user "Can see all hosts and services" permissions.
