BPI Process Unknown after 5.6.5 upgrade
rferebee
Re: BPI Process Unknown after 5.6.5 upgrade
Post by rferebee »
I made these changes (minus the setting that wasn't preset in my config file) and it's still not working.
cdienger
Post by cdienger »
max_input_vars may not exist and you can add it if it isn't in there.
Once that is done and the httpd service restarted, tail these logs:
tail -Fn0 /usr/local/nagiosxi/var/cmdsubsys.log /var/log/httpd/error_log /var/log/httpd/ssl_error_log /usr/local/nagiosxi/var/components/bpi.log
and run(on a different command line while tail is running):
su - nagios
php /usr/local/nagios/libexec/check_bpi.php DNSservice
and also try to resync the config and force some of the UNKNOWN checks to run.
rferebee
Post by rferebee »
So, do I just add the extra line of text below the other settings?
cdienger
Post by cdienger »
Anywhere under the verify first line([PHP]) should be okay.
rferebee
Post by rferebee »
Ok, I added the line and restarted apache again. No joy.
The logs keep referencing 'nagiosim' that you told me to remove (which I did).
[Mon Aug 19 13:37:37 2019] [error] [client 10.231.86.58] PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/nagiosim/nagiosim.inc.php on line 491
Here's the output from the command in the separate line:
[nagios@nagiosxi-lv ~]$ php /usr/local/nagios/libexec/check_bpi.php DNSservice
PHP Deprecated: Comments starting with '#' are deprecated in /etc/php.ini on line 440 in Unknown on line 0
PHP Deprecated: Comments starting with '#' are deprecated in /etc/php.ini on line 450 in Unknown on line 0
PHP Deprecated: Comments starting with '#' are deprecated in /etc/php.ini on line 459 in Unknown on line 0
Unknown BPI Group Index
ssax
Dreams In Code
Post by ssax »
Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
https://support.nagios.com/tickets/
rferebee
Post by rferebee »
I believe we can close this thread, Mr. Sax was able to resolve the issue.
rferebee wrote:I believe we can close this thread, Mr. Sax was able to resolve the issue.
Great!
Locking
