Config error for Exchange server and Network Switch
dmanem
Re: Config error for Exchange server and Network Switch
Post by dmanem »
The "Write monitoring data" item caused this error on the server - see file attached. The other two items did not cause any errors on the web page.
Thank you.
If you have a large setup you will need to modify the max execution time in your php.ini
Instructions below
http://support.nagios.com/wiki/index.ph ... _Completes
dmanem
Post by dmanem »
I increased the maximum execution time in the php.ini file but the error keeps popping up.
Thank you
to clarify, did your restart apache
service httpd restart
dmanem
Post by dmanem »
Yes I have restarted HTTPD services.
Can you show the new error?
Also, you large in terms of host/services is your setup?
dmanem
Post by dmanem »
The error is "PHP Fatal error: Maximum execution time of 150 seconds exceeded in /var/www/html/nagiosql/functions/config_class.php on line 1160". This is the error that pops up when I am trying to monitor a DHCP server. What execution time do you suggest?
Nagios is monitoring 510 nodes in our network at present.
Thank you.
I am starting to think we might have either a database corruption problem or a permissions problem
Lets start with the db, run the following
./repairmysql.sh nagios
./repairmysql.sh nagiosql
Then if you are still seeing the same problem, I'd like you to run the following procedure
http://library.nagios.com/library/produ ... -nagios-xi
dmanem
Post by dmanem »
I am sorry but even after running the commands and also fixing the permission rights, the same execution time error popped up.
Please run the following and attach reconfig.txt back to the forum
reconfigure_nagios.sh &> reconfig.txt
