snmpwalk -v2c -c public -m /usr/share/snmp/mibs/<MIB-NAME> <Eaton_IP>Code: Select all
snmpwalk -m +ALL -v 2c -c public <EATON_IP> .1.3.6.1.2.1.33Code: Select all
host_name redacted-Eaton-9390-UPS
service_description AlarmsPresent
use xiwizard_snmp_service
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.6.1.0 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
max_check_attempts 5
check_interval 1
retry_interval 1
notification_interval 60
notifications_enabled 0
contacts redacted
_xiwizard snmpwalk
register 1
service_description BatteryCurrent
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.2.6.0 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "Current" -u "current" -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description BatteryVoltage
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.2.5.0 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "Voltage" -u "volts" -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description BypassFrequency
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.5.1.0 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description BypassVoltage1
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.5.3.1.2.1 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description BypassVoltage2
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.5.3.1.2.2 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description BypassVoltage3
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.5.3.1.2.3 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description EstimatedChargeRemaining
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.2.4.0 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "Charge Rem" -m SNMPv2-SMI!!!!!!!
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description EstimatedMinutesRemaining
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.2.3.0 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "Minutes" -m SNMPv2-SMI!!!!!!!
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description InputFrequency1
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.3.3.1.2.1 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "in-frequency1" -m SNMPv2-SMI!!!!!!!
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description InputFrequency2
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.3.3.1.2.2 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "in-frequency2" -m SNMPv2-SMI!!!!!!!
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description InputFrequency3
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.3.3.1.2.3 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "in-frequency3" -m SNMPv2-SMI!!!!!!!
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description InputVoltage1
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.3.3.1.3.1 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "in-voltage1" -m SNMPv2-SMI!!!!!!!
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description InputVoltage2
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.3.3.1.3.2 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "in-voltage1" -m SNMPv2-SMI!!!!!!!
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description InputVoltage3
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.3.3.1.3.3 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "in-voltage1" -m SNMPv2-SMI!!!!!!!
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputCurrent1
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.3.1 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputCurrent2
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.3.2 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputCurrent3
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.3.3 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputPercentLoad
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.5.1 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputPower1
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.4.1 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputPower2
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.4.2 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputPower3
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.4.3 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputVoltage1
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.2.1 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputVoltage2
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.2.2 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description OutputVoltage3
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.4.4.1.2.3 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -m SNMPv2-SMI
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
service_description SecondsOnBattery
check_command check_xi_service_snmp! -p 161 -o mib-2.33.1.2.2.0 -P 3 --seclevel=authNoPriv --secname=user --authproto=SHA --authpasswd='redacted' -x aes -l "Seconds" -u "sec" -m SNMPv2-SMI -w 30 -c 300
check_interval 1
retry_interval 1
contacts redacted
_xiwizard snmpwalk
register 1
