Duration
orani
Re: Duration
Post by orani »
No, on service restart i do not lose the data. Only if i reboot the server itself.
Is there any way to test if on reboot i lose the /usr/local/nagios/var/retention.dat file?
Or a way to change it so not to lose that file??
Re: Duration
Typically you shouldn't lose it, but it is possible that an administrator set up some sort script or cron to delete that file.
I guess the only way to test it would be to reboot the server and on boot immediately run the following to see if it is there
ls -al /usr/local/nagios/var/retention.dat
orani
Re: Duration
Post by orani »
There is no script deleting that file on cron.
Let me check rebooting the server and running the script you suggested
orani
Re: Duration
Post by orani »
I can not understand what it is going on. I rebooted the server and immediately after reboot i run the script you told me. The file was there. I checked the duration field at the GUI and it was saying the right time, not some minutes/seconds (reboot time). The weird thing is that i didnt change anything at my configuration.
The thing is that now seems to be ok.
Re: Duration
orani wrote:The thing is that now seems to be ok.
Now that is a mystery... Glad it is working now, but I honestly have no idea why.
orani
Re: Duration
Post by orani »
also i dont have any idea why it is working but i keep that it is.
Thanks for your time. lock the thread if you want
Re: Duration
Locking
