Can't get check_nrpe to work on Windows host
craigtho
Re: Can't get check_nrpe to work on Windows host
Post by craigtho »
Updated as requested - I did comment out your example password as my server isn't configured to use one:
nsclient.ini
(9.42 KiB) Downloaded 183 times
On Nagios Server:
root@glamon2:/usr/local/nagios/libexec# ./check_nrpe -H 192.168.60.41 -p 5666
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with 192.168.60.41: 1
Following this, I edited it to say use ssl = 0 as I'm not using SSL in my configuration (yet):
nsclient.ini
nsclient.ini - edited
(9.42 KiB) Downloaded 207 times
Then on the Nagios Server:
Even after the change (and nsclient has been restarted 3 times for good measure)
If you aren't using ssl you need to add a -n to the command
./check_nrpe -H 192.168.60.41 -p 5666 -n
-n, --no-ssl                 Do no use SSL
craigtho
Post by craigtho »
Okay, thank you for your help by the way.
So I reverted that change, restarted NSClient++ and ran:
root@glamon2:/usr/local/nagios/libexec# ./check_nrpe -H 192.168.60.41 -p 5666 -n
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
At least we are getting a new error now. But sadly, still not working...I've never even seen this before.
Let's also try to add a -2 for version 2 packets
./check_nrpe -H 192.168.60.41 -p 5666 -n -2
craigtho
Post by craigtho »
Sadly, just the same response:
root@glamon2:/usr/local/nagios/libexec# ./check_nrpe -H 192.168.60.41 -p 5666 -n -2
craigtho
Post by craigtho »
Any more help would be greatly appreciated.
I've tried changing some settings and hotswapping Scott's settings with my own and continually get the same errors. I've reverted back to my last post and still getting the same errors.
craigtho
Post by craigtho »
Update: Possible Fix
NSClient.ini here:
nsclient.ini
(9.44 KiB) Downloaded 297 times
I changed ssl options = & verify mode = none
and then on the Nagios server:
root@glamon2:/usr/local/nagios/libexec# ./check_nrpe -H 192.168.60.41 -n
I (0,4,1,73 2012-12-17) seem to be doing fine...
However:
root@glamon2:/usr/local/nagios/libexec# ./check_nrpe -H 192.168.60.41 -n -c check_memory -a 'warn=free<20%' 'crit=free<10%'
CHECK_NRPE: No output returned from daemon.
Could be that this is an output due to me using Scott's config file for testing? Any advice?
craigtho
Post by craigtho »
Final Update:
My command parameter was wrong:
root@glamon2:/usr/local/nagios/libexec# ./check_nrpe -H 192.168.60.41 -n -c CheckCPU -a warn=80 crit=90 time=20m time=10s time=4
OK CPU Load ok.|'20m'=2%;80;90 '10s'=2%;80;90 '4'=7%;80;90
I think that means case is closed? Unless anything else with the .ini file needs changed that you someone can recommend.
craigtho wrote:Final Update:
Great!
Glad it is resolved!
Locking thread
