After setup RamDisk, performance graph no data?!
Re: After setup RamDisk, performance graph no data?!
xpertech wrote:another thing, what would happen if the RamDisk full? will it reset automatically? or the application on it will hang?
It will reset automatically on reboot, but once the setting are correct it should reduce it's size to normal over several hours as the performance data files are processed
xpertech
Post by xpertech »
on the "/usr/local/nagiosxi/html/config.inc.php"
can not find "cfg backup timeout =" that can be edited?
xpertech wrote:on the "/usr/local/nagiosxi/html/config.inc.php"
Where are you seeing that in the document?
What I was referring to is
$cfg['xidpe_dir'] = '/var/nagiosramdisk/spool/xidpe/';
$cfg['perfdata_spool'] = '/var/nagiosramdisk/spool/perfdata/';
xpertech
Post by xpertech »
The "cfg backup timeout =" was referred to forum(see attachment), but after adding that command, NagiosXI page was not working?!
You were missing the ; after 1800
