Using NRPE to Count Users Signed in Help
hglod
Re: Using NRPE to Count Users Signed in Help
Post by hglod »
I have the updated one attached.
But another question, am I able to use this:
Found in my nrpe config? Do I have to use an external script to monitor users on a Windows machine?
nsclient.ini
(1.3 KiB) Downloaded 125 times
I see the problem
You have this
allow nasty characters = 1
allow arguments=true
;check_user_count = check_user_count.bat
check_users=scripts\\perl\\check_users.exe $ARG1$ $ARG2$ "$ARG3$"
and what you need is this
[/settings/external scripts]
hglod
Post by hglod »
Awesome so that worked for the -a flag error. But we are back at the original error when I run "./check_nrpe -H 192.168.0.99 -c check_users -a 2 3 'cadprod.com\administrator' ":
'query' is not recognized as an internal or external command,
operable program or batch file.
OK: 0 users logged in
Active Sessions:
Can you run this from the windows command line?
scripts\perl\check_users.exe 2 3 "cadprod.com\administrator"
hglod
Post by hglod »
Same error:
Active Sessions:
Ok, you are getting the correct response at the nagios server then, now you have an issue with the plugin, you need to maybe run the help command or something on the plugin as to make sure you are passing the arguments properly.
hglod
Post by hglod »
Thank you Scott but another question. I able to use this in my nrpe config file to monitor users on a Windows machine?
hglod wrote:Thank you Scott but another question. I able to use this in my nrpe config file to monitor users on a Windows machine?
No that's not possible
