Goodnight,
Use the attached file, but the problem persists, I would appreciate the support to solve it.
[root@localhost libexec]# ./check_nrpe -H 192.168.32.16 -c check_drivesize
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with 192.168.32.16: 1
[root@localhost libexec]# ./check_nrpe -H 192.168.32.16 -c check_drivesize -a drive=C: 'warning=used>10G' 'critical=used>5G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${used} used / ${size} total}' top-syntax='${status}: ${problem_list}'
I attach the latest server files
Regards
Monitor disk space by specific value
Re: Monitor disk space by specific value
nsclient.ini- (997 Bytes) Downloaded 268 times
nsclient.log- (4.44 KiB) Downloaded 218 times
There needs to be a lot of changes done to the nsclient.ini file to post here so I created a new copy of the ini file and posted it here.
Stop the NSClient++ agent, replace the ini file and start the agent.
That should fix the issue for you and allow the nagios server the ability to connect to it.
nsclient.ini- (937 Bytes) Downloaded 234 times
I appreciate the response, I got the result without the error that came out of SSL.
I take this opportunity to consult you, referring to this topic, I created the command with the following structure
command_name check_nrpehdc
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c check_drivesize -a drive=C: 'warning=used<10G' 'critical=used<5G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${used} used / ${size} total}' top-syntax='${status}: ${problem_list}'
command_name check_nrpehde
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c check_drivesize -a drive=E: 'warning=used<10G' 'critical=used<5G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${used} used / ${size} total}' top-syntax='${status}: ${problem_list}'
Getting the following results in my web interface:
OK: {C: 13.391GB used / 59.998GB total}
OK: {E: 56.186GB used / 59.997GB total}
My question is ... because the critical service alert does not appear if the value exceeds the set value of 5G.
Best regards
Best regards
You have these set to
CRITICAL if Used space less than 5G
Do you want them to be critical if free space is less than 5G? If so
'critical=used<5G'Do you want them to be critical if free space is less than 5G? If so
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c check_drivesize -a drive=C: 'warning=free<10G' 'critical=free<5G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${used} used / ${size} total}' top-syntax='${status}: ${problem_list}'
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c check_drivesize -a drive=E: 'warning=free<10G' 'critical=free<5G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${used} used / ${size} total}' top-syntax='${status}: ${problem_list}'
}Re: Monitor disk space by specific value
Indeed, I am resolved .. thank you all for the support.
Best Regards.
Best Regards.
Great!alex3105 wrote:Indeed, I am resolved .. thank you all for the support.
Best Regards.
Locking thread
