max_check_result_file_age
sandeepatil
Re: max_check_result_file_age
Post by sandeepatil »
drwxr-sr-x 2 nagios nagios 184410112 Nov 5 19:18 checkresults
Lets run the following to correct the permissions:
chmod g-s -R checkresults
chmod g+wx -R checkresults
sandeepatil
Please find the details,
drwxr-xr-x 2 nagios nagios 218431488 Nov 13 07:01 checkresults
still not group write, execute the following
chmod g+w -R checkresults
sandeepatil
Executed shared command
drwxrwxr-x 2 nagios nagios 4096 Nov 13 08:00 checkresults
What is expected group / permission, please share the example.
That is it
And now provided your httpd/apache user is part of the nagios group things should work correctly
grep nag /etc/group
sandeepatil
Please find details
[nagios@abc123 ~]$ grep nag /etc/group
nagios:x:12366:apache,nagcmd
apache:x:2800:nagcmd,nagios
nagcmd:x:31235:nagios
That looks ok, are you still seeing the same problem you had before?
sandeepatil
We will observe for 24 Hrs and update, please confirm permission commands for checkresults dir.
