nrpe: CHECK_NRPE: Receive header underflow
fsodah
Re: nrpe: CHECK_NRPE: Receive header underflow
Post by fsodah »
sorry for not being to follow ... i searched above i can only see creating a new command ... didnt able to find the above step you mentioned
Perhaps you are not finding the check_nrpe command because you are searching for check_procs... Clear the search bar and try again. Once you find the check_nrpe command, you can click on the "Copy" actions button next to it to create a clone. Then, you can rename your "custom" new command, and add the "-2" flag to it.
Let us know if you have any further questions.
fsodah
Post by fsodah »
Done ... it works ... please close the ticket
benjaminsmith
Post by benjaminsmith »
Thanks for update. Glad to hear that took care of it.
