Schedule SSH backup failing via GUI
Re: Schedule SSH backup failing via GUI
Thanks for the output. It helps to know what OS and release the server is running.
Edit the /usr/local/nagiosxi/html/includes/constants.inc.php file and change the SB_LOGLEVEL to 0 like the following example.
define('SB_LOGLEVEL', 0);
That should enable debugging in the scheduledbackups.log file.
Run this on the nagios server and post the output so I can get the list and versions of the packages on the server. Post it here.
yum list installed |grep php
yum list installed |grep ssh
I found one possibility for the invalid format issue is a corrupted SSH public key.
Can you delete the public key on the nagios server and the entry in the authorized_keys on the Gentoo server to rule that out as the issue?
absarcompass
Post by absarcompass »
have changed logging level to debug now and have changed public private keys it didn't help though, remote server ssh log still showing invalid format
php.x86_64 5.3.3-49.el6
php-cli.x86_64 5.3.3-49.el6
php-common.x86_64 5.3.3-49.el6
php-gd.x86_64 5.3.3-49.el6
php-imap.x86_64 5.3.3-49.el6
php-ldap.x86_64 5.3.3-49.el6
php-mbstring.x86_64 5.3.3-49.el6
php-mcrypt.x86_64 5.3.3-3.el6
php-mssql.x86_64 5.3.3-3.el6
php-mysql.x86_64 5.3.3-49.el6
php-pdo.x86_64 5.3.3-49.el6
php-pear.noarch 1:1.9.4-4.el6
php-pear-HTML-Template-IT.noarch 1.3.0-2.el5
php-pecl-ssh2.x86_64 0.11.0-7.el6
php-pgsql.x86_64 5.3.3-49.el6
php-snmp.x86_64 5.3.3-49.el6
php-xml.x86_64 5.3.3-49.el6
libssh2.x86_64 1.4.2-1.el6
openssh.x86_64 5.3p1-94.el6
openssh-clients.x86_64 5.3p1-94.el6
openssh-server.x86_64 5.3p1-94.el6
Cheers
The packages look OK for the versions except for the openssh packages, they are older than the test server that I am using.
Lets enable debugging on the Gentoo server.
Edit the /etc/ssh/sshd_config file and add or edit the following entries inder the Logging section.
SyslogFacility AUTHPRIV
LogLevel DEBUG
Save the file and restart the sshd daemon
Test a SCP Transfer and check the /var/log/secure log on the Gentoo server to see more details on what is failing.
Have you tried to use the Auth Type of Password in XI to see if that works?
