I mentioned this before in a post. It isn't very logical to expect a new production server to be a base install. Quite frustrating. There are no guesses as to what I can check?scottwilkerson wrote:Now this makes more sense.
Unfortunately, installed this way really isn't supportable. With what you have told me, I would guess that the problem may be related to an Apache problem with nagiosql, but no way for me to know for sure...
NagiosXI Installation Error.
Re: NagiosXI Installation Error.
If you try to go to this in a web browser what do you get?
http://<SERVER_IP>/nagiosql/index.php
I get the directory contents as a dir listing. Perhaps I need to add in a php handler?scottwilkerson wrote:If you try to go to this in a web browser what do you get?
Yep. Nagiosql and nagiosxi both use php...
scottwilkerson wrote:Yep. Nagiosql and nagiosxi both use php...
Thank you for your help, I asked our Sr Architect, I had to just cp over conf files to a different directory to enable it. I wasn't aware of that.
Cheers
