This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
Posts: 19396 Joined: Tue Nov 15, 2011 3:11 pm
Post
by scottwilkerson » Thu Nov 14, 2019 10:36 am
I keep seeing things similar to this in your output
Nov 14 05:28:38 servername sudo[5284]: pam_unix(sudo:auth): auth could not identify password for [nagios]
Are you sure something didn't happen to your sudoers configuration?
Did someone make a change that could be cause this?
vmwareguy
Posts: 69 Joined: Wed Mar 16, 2016 9:41 am
Post
by vmwareguy » Thu Nov 14, 2019 10:44 am
well after talking to some of the knuckle heads around here it sounds like someone pushed out new stigs - I'll have to look into this more. Thanks for the help
Post
by scottwilkerson » Thu Nov 14, 2019 10:45 am
vmwareguy wrote: well after talking to some of the knuckle heads around here it sounds like someone pushed out new stigs - I'll have to look into this more. Thanks for the help
Ahhh
Good luck!
vmwareguy
Post
by vmwareguy » Thu Nov 14, 2019 11:33 am
So I have done a restore from Sunday and most everything is working. However, my Database Backend is still showing not started.
Post
by scottwilkerson » Thu Nov 14, 2019 11:42 am
vmwareguy wrote: So I have done a restore from Sunday and most everything is working. However, my Database Backend is still showing not started.
Let's run the following
service ndo2db stop
rm -f /usr/local/nagios/var/ndo.sock /usr/local/nagios/var/ndo.lock
service ndo2db start
vmwareguy
Post
by vmwareguy » Thu Nov 14, 2019 11:45 am
scottwilkerson wrote: vmwareguy wrote: So I have done a restore from Sunday and most everything is working. However, my Database Backend is still showing not started.
service ndo2db stop
Boom! Back in business. Thanks for all the help!
Post
by scottwilkerson » Thu Nov 14, 2019 11:48 am
Glad to help!
Locking thread
