(Return code of 127 is out of bounds - plugin may be missing
kmartin2007
Re: (Return code of 127 is out of bounds - plugin may be mis
Post by kmartin2007 »
here is our nagios.cfg and our services.cfg
services_nagios2.cfg
(36.3 KiB) Downloaded 329 times
nagios.cfg
(44.61 KiB) Downloaded 250 times
kmartin2007
scottwilkerson wrote:
kmartin2007 wrote:that did not work.
2019-11-15 17:41:14 2d 20h 38m 53s 2/2 (Return code of 127 is out of bounds - plugin may be missing)
Did you restart nagios?
yes i did.
You also have this command defined which doesn't have a plugin at that location
    command_name    check_url_ssl
    command_line    $USER1$/check_url_ssl
Looks like this file doesn't exist
ls -l /usr/local/nagios/libexec/check_url_ssl
kmartin2007
Thats correct. I cannot locate that plugin anywhere on the other server either. This may be something the previous guy started to play with but abandoned.
I have attached our resource.cfg as well
resource.cfg
(1.27 KiB) Downloaded 236 times
kmartin2007
oh this was installed from packages on ubuntu server 18
However, this is the command used in one of the services in your original post:
vho wrote: define service{
use production-service
host_name DALSRVPRDIIS08
service_description DCNBS.COM SSL
check_command check_url_ssl!www.DCNBS.com
kmartin2007
scottwilkerson wrote:However, this is the command used in one of the services in your original post:
right i dont think it was being used from the old server although it was created. When we inherited this it had alot of unknowns already that were ignored. We are more worried about the check_url right now, as that is a critical function to the business, and hospitals around the world that those sites are active.
kmartin2007
were now getting Return code of -1 is out of bounds now.
VIHSP ESP
Perform Extra Service Actions
CRITICAL 2019-11-15 18:00:12 2d 20h 52m 24s 2/2 (Return code of -1 is out of bounds)
ESPDATA.ORG.AU
CRITICAL 2019-11-15 17:58:00 2d 20h 57m 38s 2/2 (Return code of -1 is out of bounds)
Please post the current check_url command
Also, can you show how the command is to be run from the CLI sucessfully
Also, please post the output of
ps -ef|grep nagios.cfg
kmartin2007
scottwilkerson wrote:Please post the current check_url command
(not sure if im running this correctly)
root@dalsrvitmon03:/usr/local/nagios/libexec# ./check_url.pl -B ESPDATA.ORG.AU
rm: cannot remove 'tmp_html': No such file or directory
UNKNOWN:
command_line $USER1$/check_url.pl -I $ARG1$
root@dalsrvitmon03:/usr/local/nagios/libexec# ps -ef|grep nagios.cfg
nagios 761 1 0 17:53 ? 00:00:02 /usr/sbin/nagios3 -d /etc/nagios3/nagios.cfg
root 9633 22087 0 18:07 pts/1 00:00:00 grep --color=auto nagios.cfg
