Moving forward, all maps previously created were broken, so we've deleted them in an effort to recreate using the new version of NagVis.
NagVis > Edit Map > Add Icon > Host, then clicking produces the following error:
Failed to get objects: Error: (0) Undefined property: CorePDOHandler::$data<div class="details">URL: /nagvis/server/core/ajax_handler.php?mod=Map&act=addModify&show=TEMPLATE&type=host&x=517&y=213&_ajaxid=1576011345<br> File: /usr/local/nagvis/share/server/core/classes/CorePDOHandler.php<br> Line: 306<br> <code>#0 /usr/local/nagvis/share/server/core/classes/CorePDOHandler.php(306): nagvisExceptionErrorHandler(8, 'Undefined prope...', '/usr/local/nagv...', 306, Array)<br> #1 /usr/local/nagvis/share/server/core/classes/CorePDOHandler.php(332): CorePDOHandler->prep('SELECT name1,na...')<br> #2 /usr/local/nagvis/share/server/core/classes/GlobalBackendPDO.php(250): CorePDOHandler->query('SELECT name1,na...', Array)<br> #3 /usr/local/nagvis/share/server/core/mapcfg/default.php(145): GlobalBackendPDO->getObjects('host', '', '')<br> #4 /usr/local/nagvis/share/server/core/mapcfg/default.php(159): getObjectNames('host', Object(GlobalMapCfg), NULL, Array)<br> #5 /usr/local/nagvis/share/server/core/classes/ViewMapAddModify.php(394): listHostNames(Object(GlobalMapCfg), NULL, Array)<br> #6 /usr/local/nagvis/share/server/core/classes/ViewMapAddModify.php(509): ViewMapAddModify->drawField('host_name', Array, Array)<br> #7 /usr/local/nagvis/share/server/core/classes/ViewMapAddModify.php(537): ViewMapAddModify->drawFields(Array)<br> #8 /usr/local/nagvis/share/server/core/classes/ViewMapAddModify.php(620): ViewMapAddModify->drawForm()<br> #9 /usr/local/nagvis/share/server/core/classes/CoreModMap.php(133): ViewMapAddModify->parse()<br> #10 /usr/local/nagvis/share/server/core/functions/index.php(120): CoreModMap->handleAction()<br> #11 /usr/local/nagvis/share/server/core/ajax_handler.php(59): require('/usr/local/nagv...')<br> #12 {main}</code>Output: <pre><form id="addmodify" name="addmodify" action="javascript:submitForm('/nagvis/server/core/ajax_handler.php?mod=Map&act=addModify', 'addmodify');" method="POST"> <input type="hidden" id="_form_name" name="_form_name" value="addmodify" /> <input type="hidden" id="_update" name="_update" value="0" /> <input type="hidden" id="sec" name="sec" value="general" /> <ul class="nav" id="nav"><li id="nav_general" class="active"><a href="javascript:toggle_section('general')">General</a></li><li id="nav_appearance" ><a href="javascript:toggle_section('appearance')">Appearance</a></li><li id="nav_state" ><a href="javascript:toggle_section('state')">Status</a></li><li id="nav_actions" ><a href="javascript:toggle_section('actions')">Actions</a></li><li id="nav_label" ><a href="javascript:toggle_section('label')">Label</a></li><li id="nav_worldmap" ><a href="javascript:toggle_section('worldmap')">Worldmap</a></li></ul><div id="sec_general" class="section" style=""><table class="mytable"><tr class="must"><td class=tdlabel>host_name</td><td class=tdbox></td><td class=tdfield></pre>
