Email alert: message not appearing
Re: Email alert: message not appearing
I got most of the files, I didn't get the profile in the message you sent. If you could send that again, that would be great.
But in looking at the screenshots, I'm wondering if there is a limit to the amount of data that can fit into the message variable. Can you try setting up a test alert against a log with a smaller message and see if it comes through in an email?
We have shorter messages, around 5 lines, and they also don't make it.mbellerue wrote: But in looking at the screenshots, I'm wondering if there is a limit to the amount of data that can fit into the message variable. Can you try setting up a test alert against a log with a smaller message and see if it comes through in an email?
The only issue I'm seeing is that there seems to be something technically wrong with the HTML in your email template. All of the HTML validators I've run it through say that the /p at line 4 is unexpected. Put it anywhere before the div, and it's fine. That being said, I was able to put it into an email template on my Log Server 2.1.2, and everything comes through as expected.
Could you create a new email template that literally consists of just,
And see if you get the data as expected?
Output: %output%
Last 10: %last10alertlogs%
Lookback: %lookback%
URL: %url%As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
mbellerue wrote:The only issue I'm seeing is that there seems to be something technically wrong with the HTML in your email template. All of the HTML validators I've run it through say that the /p at line 4 is unexpected. Put it anywhere before the div, and it's fine. That being said, I was able to put it into an email template on my Log Server 2.1.2, and everything comes through as expected.
And see if you get the data as expected?Code: Select all
Output: %output% Last 10: %last10alertlogs% Lookback: %lookback% URL: %url%
Template created; we'll see what happens.
-- Mike Beebe
Sounds good. We'll keep the thread open and wait to hear back.
Unfortunately, this did not work. The message still isn't appearing.mbellerue wrote:Sounds good. We'll keep the thread open and wait to hear back.
Any other ideas?
-- Mike Beebe
Is this a real-time check?
It is not. It's a standard alert.mbellerue wrote:Is this a real-time check?
Alright, one more thing we should try is using a template that just has the %last10alertlogs% macro in it. Just in case one of the other macros is somehow conflicting with that macro. Then also a template with just %lastalertlog%.
Ok -- I'll give that a try. Thanks.mbellerue wrote:Alright, one more thing we should try is using a template that just has the %last10alertlogs% macro in it. Just in case one of the other macros is somehow conflicting with that macro. Then also a template with just %lastalertlog%.
