Nagios XI Webconsole is blank
Re: Nagios XI Webconsole is blank
Do i need to again run "repair_databases.sh" script to resolve this issue ?
Yes, run the "repair_databases.sh" script, and check the mysqld.log for errors again. If there are no errors, try restarting services to see if this is going to help:
service nagios stop
service ndo2db restart
service postgresql restart
service nagios start
Check the status of the services:
service nagios status
service ndo2db status
service postgresql status
Also, PM me your latest profile:
Admin > System Config > System Profile > Download Profile > profile.zip > Save File
lgaddam
Post by lgaddam »
I have done repair script once again.
Now those errors are gone. mysqld.log looks good now.
Are you still seeing blank pages in the GUI or it is all working correctly? Is it safe to lock this thread? Thanks!
lgaddam
Post by lgaddam »
Only mysqld.log errors got fixed. Still the blank webconsole persists.
Not able to download profile.zip because of blank console.
Let's try to get the profile from the command line. One of the files will be missing, but at least we can review the rest of the files.
1. Run the following command from the command line:
/usr/local/nagiosxi/scripts/components/getprofile.sh 1234
2. Check to see if the "profile.zip" file was created in the "/usr/local/nagiosxi/var/components" directory:
cd /usr/local/nagiosxi/var/components
ls -la
3. Use FileZilla or similar file transfer program to copy over the "profile.zip" file to your computer.
4. PM me the profile.zip file
Note: After this, you could remote the profile.zip that was created in the "/usr/local/nagiosxi/var/components" directory, along with the profile folder (which should be empty).
rm -rf profile profile.zip
lgaddam
Post by lgaddam »
HI,
I got below error while I try to run the provided command by you.
[root@glnagiosp02 etc]# /usr/local/nagiosxi/scripts/components/getprofile.sh 1234
-bash: /usr/local/nagiosxi/scripts/components/getprofile.sh: No such file or directory
By bad - the profile creation was done differently in the old versions of XI, e.g. 5.4.3.
Let's try this:
mkdir -p /usr/local/nagiosxi/var/components/profile
cd /usr/local/nagiosxi/html/includes/components/profile
./getprofile.sh
After running these commands, a profile.zip file should be created ("/usr/local/nagiosxi/var/components/profile.zip"). PM me the file when you get it.
Does the "/usr/local/nagiosxi/html/index.php" file exist on your system? Run the following commands and show the output:
ls -lad /usr/local /usr/local/nagiosxi /usr/local/nagiosxi/html/
ls -la /usr/local/nagiosxi/html/index.php
Can you also run the following command, and show the output in code wraps?
yum list installed | grep php
lgaddam
Post by lgaddam »
Issue got resolved.
Issue is with permissions in /etc/group. It has been corrected as below.
Earlier:
nagios:x:57975:nagios:apache:snmptt
nagcmd:x:57976:nagios:apache:snmptt
After correction:
nagios:x:57975:nagios,apache,snmptt
nagcmd:x:57976:nagios,apache,snmptt
Then restart httpd:
service httpd restart
Issue resolved. Please close this.
lgaddam wrote:Hi,
Issue got resolved.
Earlier:
After correction:
Then restart httpd:
Great!
Locking thread
