NRPE Unable to read output
mccrakem
Re: NRPE Unable to read output
Post by mccrakem »
Screenshots and nrpe.cfg file attached
Can you su as "nrpe" user on the client (remote machine), and run your script without being prompted for a password?
su - nrpe
sudo /usr/lib64/nagios/plugins/check_ucard_backups.sh
mccrakem
Post by mccrakem »
Hi
No it goes to a prompt but when I try and run the script it prompts for the password for the nrpe user
Can you PM me your sudoers file? If you have more than one file, e.g. a file in /etc/sudoers.d directory, PM me this one as well.
In addition to the "standard" sudoers, do you have by chance sudo configured via LDAP as well? If you do, we would need to see these configs too.
