Transaction Timeout Anomalies for SSH Access
louissiong
Re: Transaction Timeout Anomalies for SSH Access
Thanks. We are almost there. I made some changes to the idea u gave and came out with a script .But based on the wrapper script, is there a way to show multiple status outputs instead of just one with the service checks ? Eg. From the screenshot, only STATE_OK is generated whereas any service check with STATE_CRITICAL or WARNING is ignored.
Can these be produced too ? Where did I go wrong ?
Please help. Thanks.
#!/usr/bin/sh
qmiib01abt=$(/usr/local/nagios/check/check_mq_channel.sh QMIIB01 ABT*)
qmpgct01abt=$(/usr/local/nagios/check/check_mq_channel.sh QMPGCT01 ABT*)
qmpgs01abt=$(/usr/local/nagios/check/check_mq_channel.sh QMPGS01 ABT*)
cd /usr/local/nagios/check/
if [[ ! -f check_mq_channel.sh ]]; then
exit 0
else
echo "QMIIB01 ABT: ${qmiib01abt}, QMPGCT01 ABT: ${qmpgct01abt}, QMPGS01 ABT: ${qmpgs01abt}"
fi
Regards,
Louis
#!/usr/bin/sh
exit 0
else
fi
Regards,
Louis
That is a great start, and honestly better than what I was thinking of for handling the return messages. Your script is hard coded to give an exit code of 0 if the check_mq_channels.sh file does not exist. If it does exist, then the script runs and does its thing. The only exit code that it provides is whether or not the script itself ran.
The exit code is how Nagios determines whether something is OK, WARNING, CRITICAL, or UNKNOWN. 0,1,2,3+, respectively. Try this.
Give that a shot and let me know how it goes. Definitely double check that I spelled all the variables correctly. I have been known to typo once in a while.
#!/usr/bin/sh
#Setting returnresult to 3, so if something is broken it will return UNKNOWN
returnresult=3
if [[ ! -f /usr/local/nagios/check/check_mq_channel.sh ]]; then
#Setting this to critical, because if the check_mq_channel.sh file doesn't exist, that's a big problem
returnresult=2
else
#Putting all of these as part of the check to see if the check_mq_channel.sh file exists.
#If the file didn't exist, we would have received a bunch of errors since sh would have tried to execute the commands, then check to see if the file was there.
checkmq1=$?
checkmq2=$?
checkmq3=$?
if [ $(($checkmq1 + $checkmq2 + $checkmq3)) -gt 0 ]; then
#If any of the results' exit code is greater than 0, the check returns CRITICAL
returnresult=2
else
returnresult=0
fi
fi
#Personal preference, I like having scripts exit in one place. All of the logic prior to exiting determines the exit code.
exit $returnresult
louissiong
Thank a lot for your enlightenment.
The script does a great job identifying the status of the service check for 'QMPGCT01 ABT: Following Channels are not running : ABT.SVRCONN'
which is in critical state. However, it fails in doing so for the rest 'QMIIB01 ABT: Channels are running' and 'QMPGS01 ABT: Channels are running'
that are practically up and running (OK state).
Is it possible for Nagios to output their service status as well collectively ?
Channel Wrapper QMIIB01 Critical 7m 10s 10/10 2020-02-11 11:01:57 QMIIB01 ABT: Channels are running, QMPGCT01 ABT: Following Channels are not running : ABT.SVRCONN, QMPGS01 ABT: Channels are running
Regards,
Louis
Regards,
Louis
Isn't that what the script is already outputting? If one of the services goes down, it should throw a critical. And then in the message it specifies which services are running and which services are down. Or am I reading it incorrectly?
louissiong
Yes, it is showing but not on a line by line format. Eg. OK -- QMIIB01 ABT: Channels are running, Critical -- QMPGCT01 ABT: Following Channels are not running : ABT.SVRCONN, OK -- QMPGS01 ABT: Channels are running.
Does Nagios XI support such functionality?? Thanks.
louissiong
Basically, this is for ease of reading and monitoring by other Teamslouissiong wrote:Yes, it is showing but not on a line by line format. Eg. OK -- QMIIB01 ABT: Channels are running, Critical -- QMPGCT01 ABT: Following Channels are not running : ABT.SVRCONN, OK -- QMPGS01 ABT: Channels are running.
Oh yes, there are two ways to do this. The easiest is to just use a \n wherever you want a line break. If that doesn't work, you can use <br /> tags, but you have to enable HTML processing in Admin -> System Settings.
louissiong
Thanks for your advice. Tried adding the \n to the script but still it doesn't display the service status on a line by line format.
Please refer to the script below. It only echos out the results. Is there any additional codes required or the conditions should be separated instead ?
#!/usr/bin/sh
retresult=3
retresult=2
else
checkmq1=$?
checkmq2=$?
checkmq3=$?
retresult=2
else
retresult=0
fi
echo "QMIIB01 ABT: ${qmiib01abt}\n"
echo "QMPGCT01 ABT: ${qmpgct01abt}\n"
echo "QMPGS01 ABT: ${qmpgs01abt}"
fi
exit $retresult
#!/usr/bin/sh
retresult=3
retresult=2
else
checkmq1=$?
checkmq2=$?
checkmq3=$?
retresult=2
else
retresult=0
fi
fi
exit $retresult
Okay, then let's try this with HTML. Go to Admin -> System Settings and check the "Allow HTML Tags in Host/Service Status" checkbox. Then modify the output portion of your script like so,
And that should get you your line breaks.
echo "QMIIB01 ABT: ${qmiib01abt}<br \>"
echo "QMPGCT01 ABT: ${qmpgct01abt}<br \>"
echo "QMPGS01 ABT: ${qmpgs01abt}"As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
louissiong
Still not working. Need to add any conditions beforehand to output the service status ?
Thanks.
Thanks.
