Nagios Service Not Starting
amitgupta19
Re: Nagios Service Not Starting
Post by amitgupta19 »
Thanks Scott for the Update
I was trying to install the NDOUTils... got the following error:
I am following the step mentioned in the URL:
https://support.nagios.com/kb/article/n ... acle_Linux
[amgupta@xxxnagios3 tmp]$ sudo systemctl start mysqld.service
Failed to start mysqld.service: Unit not found.
In the Previous step to the above step:
sudo yum install -y mysql mysql-server mysql-devel perl-DBD-MySQL
it gave the folowing message: No package mysql-server available.
Kindly Suggest..
What OS and version are you running?
I see you said in the 1st post OEL 7
Did you run the following?
cd /tmp
wget http://repo.mysql.com/mysql-community-release-el7-5.noarch.rpm
rpm -ivh mysql-community-release-el7-5.noarch.rpm
yum update
amitgupta19
yes i have followed all the steps.
Can you show the output of the following
ll /etc/yum.repos.d/mysql-community*
yum repolist
amitgupta19
[amgupta@xxnagios3 tmp]$ ll /etc/yum.repos.d/mysql-community*
-rw-r--r--. 1 root root 1209 Jan 29 2014 /etc/yum.repos.d/mysql-community.repo-bkp
-rw-r--r--. 1 root root 1060 Jan 29 2014 /etc/yum.repos.d/mysql-community-source.repo-bkp
[amgupta@xxxnagios3 tmp]$ yum repolist
Loaded plugins: ulninfo
repo id repo name status
GIA-CentOS7-Local GIA CentOS Local 17,216
GIA_LOCAL_ol7_UEK3_latest Latest Unbreakable Enterprise Kernel 3 for Oracle Linux 7Server (x86_64) 119
GIA_LOCAL_ol7_UEK4_latest Latest Unbreakable Enterprise Kernel 4 for Oracle Linux 7Server (x86_64) 35
GIA_LOCAL_ol7_UEK5_latest Latest Unbreakable Enterprise Kernel 5 for Oracle Linux 7Server (x86_64) 80
GIA_LOCAL_ol7_addons Latest Unbreakable Enterprise addon for Oracle Linux 7Server (x86_64) 94
GIA_LOCAL_ol7_latest Oracle Linux 7 Latest (x86_64) 7Server (x86_64) 5,411
epel/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 13,524
repolist: 36,479
amitgupta19
Attaching the output in a file in case the previous one is not clear..
Nagios.docx
(36.96 KiB) Downloaded 236 times
Ok, it looks like the RPM didn't instalkl the packages maybe becasause you have an old version from befor
Run the following
cd /tmp
sudo rpm -Uvh --force mysql-community-release-el7-5.noarch.rpm
sudo yum update
then, provided there are no errors
