check_mrtgtraf: Unable to open MRTG log file
Phillyidol
Re: check_mrtgtraf: Unable to open MRTG log file
Post by Phillyidol »
Thanks scottwilkerson,
I completely understand. I just thot the 'WorkDir' info was in a Nagios cfg/conf file that the mrtg process was pulling from, as I can't seem to find a 'WorkDir' entry in any of the mrtg cfg/conf files I've looked thru.
I'll go thru the documentation you sent and see how it lines up against the install tutorial I used.
Thanks again
Phillyidol wrote:I'll go thru the documentation you sent and see how it lines up against the install tutorial I used.
Thanks again
Sounds good
