Host and Service Trends
amitgupta19
Re: Host and Service Trends
Post by amitgupta19 »
Please find attached.
messages_log.txt
(102.14 KiB) Downloaded 577 times
httpd_log.txt
(731 Bytes) Downloaded 1014 times
Post by Box293 »
Can you please post a copy of /usr/local/nagios/etc/nagios.cfg
amitgupta19
PFA
nagios.cfg
Nagios.cfg file
(46.56 KiB) Downloaded 625 times
amitgupta19
Dear Box any update on it?
Those menus rely on the a few packages being installed and they may not of been installed.
Try installing these packages.
gd
gd-devel
png-devel
jpeg-devel
Then you will have to re-configure the nagios source, recompile and install it.
You should see the trends.cgi file here.
/usr/local/nagios/sbin/trends.cgi
and the trends html files here
/usr/local/nagios/share
If so, then you should be able to access the web links.
amitgupta19
Thanks for the reply:
trends.cgi file is missing.
Trends html files are available at the Location
Following files are present:
trends-form.html
trends-graph.html
trends-host-yaxis.html
trends.html
trends-links.html
trends-service-yaxis.html
Also i tried to install the Packages mentioned by you following is the update:
gd --- It is Already installed.
Package gd-2.0.35-26.el7.x86_64 already installed and latest version
Nothing to do
gd-devel ---It was Missing and Installed it.
png-devel -- When i try to install, it is giving the following error:
No package png-devel available.
Error: Nothing to do
Also this Package is not listed in the Prerequisite of Nagios.
jpeg-devel
Loaded plugins: ulninfo
No package jpeg-devel available.
Kindly how to install the following 2 packages: png-devel and jpeg-devel ???
Post by Box293 »
It's possible that the gd-devel package that you just installed included the jpeg libraries. Can you try the recompile steps and seen if your problem is now installed.
amitgupta19
Thanks Box for the update.
Just want to be sure, kindly confirm that i need to do only the following steps as suggested by you and tgriep.
Downloading the Source
cd /tmp
wget -O nagioscore.tar.gz https://github.com/NagiosEnterprises/na ... 4.5.tar.gz
tar xzf nagioscore.tar.gz
Compile
cd /tmp/nagioscore-nagios-4.4.5/
./configure
make all
Install Binaries
make install
amitgupta19
Hi Box,
Can you please check and confirm the steps?
amitgupta19
Can anyone confirm that i have to use the below steps only?
cd /tmp
Compile
./configure
make all
Install Binaries
make install
