I have ran the to commands below:
[root@k]# ls -l /usr/local/nagiosxi/var/dbmaint.log
-rw-r--r-- 1 nagios nagios 797884 Mar 30 17:10 /usr/local/nagiosxi/var/dbmaint.log
[root@k]#
[root@k]# tail -50 /usr/local/nagiosxi/var/dbmaint.log
SQL: OPTIMIZE TABLE nagios_programstatus
OPTIMIZING NDOUTILS TABLE: nagios_runtimevariables
SQL: OPTIMIZE TABLE nagios_runtimevariables
OPTIMIZING NDOUTILS TABLE: nagios_scheduleddowntime
SQL: OPTIMIZE TABLE nagios_scheduleddowntime
OPTIMIZING NDOUTILS TABLE: nagios_service_contactgroups
SQL: OPTIMIZE TABLE nagios_service_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_service_contacts
SQL: OPTIMIZE TABLE nagios_service_contacts
OPTIMIZING NDOUTILS TABLE: nagios_servicechecks
SQL: OPTIMIZE TABLE nagios_servicechecks
OPTIMIZING NDOUTILS TABLE: nagios_servicedependencies
SQL: OPTIMIZE TABLE nagios_servicedependencies
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalation_contactgroups
SQL: OPTIMIZE TABLE nagios_serviceescalation_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalation_contacts
SQL: OPTIMIZE TABLE nagios_serviceescalation_contacts
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalations
SQL: OPTIMIZE TABLE nagios_serviceescalations
OPTIMIZING NDOUTILS TABLE: nagios_servicegroup_members
SQL: OPTIMIZE TABLE nagios_servicegroup_members
OPTIMIZING NDOUTILS TABLE: nagios_servicegroups
SQL: OPTIMIZE TABLE nagios_servicegroups
OPTIMIZING NDOUTILS TABLE: nagios_services
SQL: OPTIMIZE TABLE nagios_services
OPTIMIZING NDOUTILS TABLE: nagios_servicestatus
SQL: OPTIMIZE TABLE nagios_servicestatus
OPTIMIZING NDOUTILS TABLE: nagios_statehistory
SQL: OPTIMIZE TABLE nagios_statehistory
OPTIMIZING NDOUTILS TABLE: nagios_systemcommands
SQL: OPTIMIZE TABLE nagios_systemcommands
OPTIMIZING NDOUTILS TABLE: nagios_timedeventqueue
SQL: OPTIMIZE TABLE nagios_timedeventqueue
OPTIMIZING NDOUTILS TABLE: nagios_timedevents
SQL: OPTIMIZE TABLE nagios_timedevents
OPTIMIZING NDOUTILS TABLE: nagios_timeperiod_timeranges
SQL: OPTIMIZE TABLE nagios_timeperiod_timeranges
OPTIMIZING NDOUTILS TABLE: nagios_timeperiods
SQL: OPTIMIZE TABLE nagios_timeperiods
CLEANING nagiosxi TABLE 'commands'...
SQL: DELETE FROM xi_commands WHERE processing_time < 1585548001::abstime::timestamp without time zone AND status_code = 2
CLEANING nagiosxi TABLE 'events'...
SQL: DELETE FROM xi_events WHERE processing_time < 1585548001::abstime::timestamp without time zone AND status_code = 2
CLEANING nagiosxi TABLE 'auth_tokens'...
SQL: DELETE FROM xi_auth_tokens WHERE auth_valid_until < 1585490401::abstime::timestamp without time zone
CLEANING nagiosxi TABLE 'cmp_trapdata_log'...
SQL: DELETE FROM xi_cmp_trapdata_log WHERE trapdata_log_datetime < 1577800801::abstime::timestamp without time zone
SQL1: SELECT xi_meta.meta_id FROM xi_meta LEFT JOIN xi_events ON xi_meta.metaobj_id=xi_events.event_id WHERE metatype_id='1' AND event_id IS NULL
LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' EXISTS - EXITING!
[root@k]#
Update Nagios XI 5.4.13 to Nagios XI is 5.6.12 not Working
martinkuriax
Re: Update Nagios XI 5.4.13 to Nagios XI is 5.6.12 not Worki
I'm going to recommend you open a ticket for the DB Maintenance issue and we will likely need to exchange a fair amount of information to get it resolved
Please open a ticket here
https://support.nagios.com/tickets/
martinkuriax
The Database Maintenance color RED has cleared, thanks again for your supportive solutions, the POST can be closed, thanks
Great!martinkuriax wrote:The Database Maintenance color RED has cleared, thanks again for your supportive solutions, the POST can be closed, thanks
Locking thread
