We are using Xclarity 2.6.0 version.
Can we use Xclarity 1.1.0 for the same?
If so below is the output after rying to run it with su - nagios user.
It seems libraries has to be added.
-bash-4.2$ python /usr/local/nagios/libexec/Xclarity_integrator_check.py generate_credentials
Traceback (most recent call last):
File "/usr/local/nagios/libexec/Xclarity_integrator_check.py", line 11, in <module>
from keyrings.cryptfile.cryptfile import CryptFileKeyring
File "/usr/lib/python2.7/site-packages/keyrings.cryptfile-1.3.4-py2.7.egg/keyrings/cryptfile/cryptfile.py", line 7, in <module>
from keyring.util import properties
ImportError: cannot import name properties
Please let me know how i can add this library.
Monitoring Lenovo xclarity using Nagios
Re: Monitoring Lenovo xclarity using Nagios
We have added the commdn below.
$USER1$/xclarity_integrator_check_v1.0.0.py --lxca system
And here is the error in Nagios XI.
Warning
(No output on stdout) stderr: Traceback (most recent call last):
File "/usr/local/nagios/libexec/xclarity_integrator_check_v1.0.0.py", line 553, in <module>
status_lxca_bad, status_lxca_good, exit_status = check_lxca(_args, write_to_log_flag)
File "/usr/local/nagios/libexec/xclarity_integrator_check_v1.0.0.py", line 483, in check_lxca
bad_devices, good_devices, exit_status = get_bad_devices(_args.lxca)
File "/usr/local/nagios/libexec/xclarity_integrator_check_v1.0.0.py", line 206, in get_bad_devices
devices = get_devices(lxca_instance).get("nodeList")
File "/usr/local/nagios/libexec/xclarity_integrator_check_v1.0.0.py", line 92, in get_devices
return api_call("{0}/nodes?includeAttributes=name,overallHealthState,ipv4Addresses&status=managed".format(storedUrl), lxca_instance)
File "/usr/local/nagios/libexec/xclarity_integrator_check_v1.0.0.py", line 74, in api_call
f.write(certificate)
TypeError: expected a character buffer object
Warning
The system requirements show that it requires python 3.5.2 at the minimum:
https://sysmgt.lenovofiles.com/help/top ... cp=6_3_3_0
Let me look to see how this is done.
Run these commands to set it up:
Use this for your command line:
cd /usr/local/nagios/libexec
wget https://download.lenovo.com/servers/xclarity_integrator_check.py
chown apache.nagios xclarity_integrator_check.py
chmod ug+x xclarity_integrator_check.py
yum install python3 python36-keyring python36-requests -y
pip3 install keyrings.cryptfile pbkdf2
su - nagios
python3 xclarity_integrator_check.py generate_credentialsCode: Select all
command_line /bin/python3 $USER1$/xclarity_integrator_check.py --lxca systemRe: Monitoring Lenovo xclarity using Nagios
We have done the setup as advised.
But when we try to send the trap from Xclarity we are getting it in tcpdump.
We cannot see it in the snmp logs or the unknown logs and also not in the received traps in NagiosXI even we defined the MIB events.
PS: we are able to see other traps to confirm that it is working.
Thanks.
Thanks.
I don't think that plugin has anything to do with SNMP traps.
Does this command now work?
For SNMP traps, did you follow this guide?
Are you seeing them in Admin > Unconfigured Objects?
/bin/python3 /usr/local/nagios/libexec/xclarity_integrator_check.py --lxca systemCode: Select all
https://assets.nagios.com/downloads/nagiosxi/docs/SNMP-Traps-With-NXTI.pdf
