Is there a number of Client or services Nagios can connect?
Re: Is there a number of Client or services Nagios can conne
not there either
command didnt work, server still overloaded.
no such file
benjaminsmith
Hello @jlamar,
Can you send me a fresh copy of the system profile? Also, did you add the new hosts yet?
Thanks.
Benjamin
Thanks.
Benjamin
I havent added the other yet. here is the profile
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum.
benjaminsmith
Hello @jlamar,
Thanks for sending over the latest profile. That database log looks better. A couple more steps to help boost the performance on this server.
1. Take a backup and upgrade to the latest version, we've made a number of improvements since 5.5.11.
https://assets.nagios.com/downloads/nag ... ctions.pdf
2. Run the following query and post the output to check the size of the database tables. Truncating large tables will help increase performance.
3. I highly recommend increasing the amount of RAM and CPU's ,it's below the minimum specifications for the number of checks you have.
https://assets.nagios.com/downloads/nag ... ements.pdf
4. The perf data processing is hitting the upper limits.
I would recommend increasing the timeout settings by following the guide below.
https://support.nagios.com/kb/article/n ... ems-9.html
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
2020-04-03 12:42:50 [27120] [0] *** Timeout while processing Host: "ctx-xa2012p22.nrmc.org" Service: "Ping"
2020-04-03 12:42:50 [27120] [0] *** process_perfdata.pl terminated on signal ALRM
2020-04-03 12:42:50 [27118] [0] *** TIMEOUT: Timeout after 5 secs. ***
Last login: Mon Apr 13 08:04:08 2020 from 10.150.1.207
[itadmin@vs900365 ~]$ echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
| Table | Size in MB |
| nagios_acknowledgements | 0.04 |
| nagios_commands | 0.02 |
| nagios_commenthistory | 2.19 |
| nagios_comments | 0.02 |
| nagios_configfiles | 0.00 |
| nagios_configfilevariables | 0.01 |
| nagios_conninfo | 0.20 |
| nagios_contact_addresses | 0.00 |
| nagios_contact_notificationcommands | 0.01 |
| nagios_contactgroup_members | 0.00 |
| nagios_contactgroups | 0.00 |
| nagios_contactnotificationmethods | 3.26 |
| nagios_contactnotifications | 3.47 |
| nagios_contacts | 0.00 |
| nagios_contactstatus | 0.00 |
| nagios_customvariables | 0.36 |
| nagios_customvariablestatus | 0.35 |
| nagios_dbversion | 0.00 |
| nagios_downtimehistory | 0.39 |
| nagios_eventhandlers | 0.21 |
| nagios_externalcommands | 0.00 |
| nagios_flappinghistory | 0.97 |
| nagios_host_contactgroups | 0.00 |
| nagios_host_contacts | 0.03 |
| nagios_host_parenthosts | 0.00 |
| nagios_hostchecks | 0.00 |
| nagios_hostdependencies | 0.00 |
| nagios_hostescalation_contactgroups | 0.00 |
| nagios_hostescalation_contacts | 0.00 |
| nagios_hostescalations | 0.00 |
| nagios_hostgroup_members | 0.04 |
| nagios_hostgroups | 0.00 |
| nagios_hosts | 0.26 |
| nagios_hoststatus | 0.55 |
| nagios_instances | 0.00 |
| nagios_logentries | NULL |
| nagios_notifications | 77.60 |
| nagios_objects | 0.84 |
| nagios_processevents | 0.29 |
| nagios_programstatus | 0.00 |
| nagios_runtimevariables | 0.00 |
| nagios_scheduleddowntime | 0.00 |
| nagios_service_contactgroups | 0.00 |
| nagios_service_contacts | 0.16 |
| nagios_service_parentservices | 0.00 |
| nagios_servicechecks | 0.00 |
| nagios_servicedependencies | 0.00 |
| nagios_serviceescalation_contactgroups | 0.00 |
| nagios_serviceescalation_contacts | 0.03 |
| nagios_serviceescalations | 0.06 |
| nagios_servicegroup_members | 0.00 |
| nagios_servicegroups | 0.00 |
| nagios_services | 0.99 |
| nagios_servicestatus | 2.46 |
| nagios_statehistory | 85.71 |
| nagios_systemcommands | 0.04 |
| nagios_timedeventqueue | 0.00 |
| nagios_timedevents | 0.00 |
| nagios_timeperiod_timeranges | 0.01 |
| nagios_timeperiods | 0.00 |
| tbl_command | 0.06 |
| tbl_contact | 0.03 |
| tbl_contactgroup | 0.03 |
| tbl_contacttemplate | 0.03 |
| tbl_domain | 0.03 |
| tbl_host | 0.27 |
| tbl_hostdependency | 0.03 |
| tbl_hostescalation | 0.03 |
| tbl_hostextinfo | 0.03 |
| tbl_hostgroup | 0.03 |
| tbl_hosttemplate | 0.03 |
| tbl_info | 0.17 |
| tbl_lnkContactToCommandHost | 0.02 |
| tbl_lnkContactToCommandService | 0.02 |
| tbl_lnkContactToContactgroup | 0.02 |
| tbl_lnkContactToContacttemplate | 0.02 |
| tbl_lnkContactToVariabledefinition | 0.02 |
| tbl_lnkContactgroupToContact | 0.02 |
| tbl_lnkContactgroupToContactgroup | 0.02 |
| tbl_lnkContacttemplateToCommandHost | 0.02 |
| tbl_lnkContacttemplateToCommandService | 0.02 |
| tbl_lnkContacttemplateToContactgroup | 0.02 |
| tbl_lnkContacttemplateToContacttemplate | 0.02 |
| tbl_lnkContacttemplateToVariabledefinition | 0.02 |
| tbl_lnkHostToContact | 0.05 |
| tbl_lnkHostToContactgroup | 0.02 |
| tbl_lnkHostToHost | 0.02 |
| tbl_lnkHostToHostgroup | 0.06 |
| tbl_lnkHostToHosttemplate | 0.06 |
| tbl_lnkHostToVariabledefinition | 0.06 |
| tbl_lnkHostdependencyToHost_DH | 0.02 |
| tbl_lnkHostdependencyToHost_H | 0.02 |
| tbl_lnkHostdependencyToHostgroup_DH | 0.02 |
| tbl_lnkHostdependencyToHostgroup_H | 0.02 |
| tbl_lnkHostescalationToContact | 0.02 |
| tbl_lnkHostescalationToContactgroup | 0.02 |
| tbl_lnkHostescalationToHost | 0.02 |
| tbl_lnkHostescalationToHostgroup | 0.02 |
| tbl_lnkHostgroupToHost | 0.02 |
| tbl_lnkHostgroupToHostgroup | 0.02 |
| tbl_lnkHosttemplateToContact | 0.02 |
| tbl_lnkHosttemplateToContactgroup | 0.02 |
| tbl_lnkHosttemplateToHost | 0.02 |
| tbl_lnkHosttemplateToHostgroup | 0.02 |
| tbl_lnkHosttemplateToHosttemplate | 0.02 |
| tbl_lnkHosttemplateToVariabledefinition | 0.02 |
| tbl_lnkServiceToContact | 0.13 |
| tbl_lnkServiceToContactgroup | 0.02 |
| tbl_lnkServiceToHost | 0.13 |
| tbl_lnkServiceToHostgroup | 0.02 |
| tbl_lnkServiceToServicegroup | 0.02 |
| tbl_lnkServiceToServicetemplate | 0.13 |
| tbl_lnkServiceToVariabledefinition | 0.13 |
| tbl_lnkServicedependencyToHost_DH | 0.02 |
| tbl_lnkServicedependencyToHost_H | 0.02 |
| tbl_lnkServicedependencyToHostgroup_DH | 0.02 |
| tbl_lnkServicedependencyToHostgroup_H | 0.02 |
| tbl_lnkServicedependencyToService_DS | 0.02 |
| tbl_lnkServicedependencyToService_S | 0.02 |
| tbl_lnkServicedependencyToServicegroup_DS | 0.02 |
| tbl_lnkServicedependencyToServicegroup_S | 0.02 |
| tbl_lnkServiceescalationToContact | 0.02 |
| tbl_lnkServiceescalationToContactgroup | 0.02 |
| tbl_lnkServiceescalationToHost | 0.02 |
| tbl_lnkServiceescalationToHostgroup | 0.02 |
| tbl_lnkServiceescalationToService | 0.02 |
| tbl_lnkServiceescalationToServicegroup | 0.02 |
| tbl_lnkServicegroupToService | 0.02 |
| tbl_lnkServicegroupToServicegroup | 0.02 |
| tbl_lnkServicetemplateToContact | 0.02 |
| tbl_lnkServicetemplateToContactgroup | 0.02 |
| tbl_lnkServicetemplateToHost | 0.02 |
| tbl_lnkServicetemplateToHostgroup | 0.02 |
| tbl_lnkServicetemplateToServicegroup | 0.02 |
| tbl_lnkServicetemplateToServicetemplate | 0.02 |
| tbl_lnkServicetemplateToVariabledefinition | 0.02 |
| tbl_lnkTimeperiodToTimeperiod | 0.02 |
| tbl_logbook | 0.02 |
| tbl_mainmenu | 0.02 |
| tbl_permission | 0.02 |
| tbl_permission_inactive | 0.02 |
| tbl_service | 1.52 |
| tbl_servicedependency | 0.03 |
| tbl_serviceescalation | 0.03 |
| tbl_serviceextinfo | 0.03 |
| tbl_servicegroup | 0.03 |
| tbl_servicetemplate | 0.03 |
| tbl_session | 0.02 |
| tbl_session_locks | 0.02 |
| tbl_settings | 0.03 |
| tbl_submenu | 0.02 |
| tbl_timedefinition | 0.02 |
| tbl_timeperiod | 0.03 |
| tbl_user | 0.03 |
| tbl_variabledefinition | 0.28 |
| xi_auditlog | 102.70 |
| xi_auth_tokens | 0.19 |
| xi_cmp_trapdata | 0.03 |
| xi_cmp_trapdata_log | 0.03 |
| xi_commands | 0.06 |
| xi_eventqueue | 0.03 |
| xi_events | 0.20 |
| xi_incidents | 0.02 |
| xi_meta | 2.52 |
| xi_mibs | 0.05 |
| xi_options | 0.05 |
| xi_sessions | 0.03 |
| xi_sysstat | 0.03 |
| xi_usermeta | 0.22 |
| xi_users | 0.03 |
| tbl_domain | 0.03 |
| tbl_host | 0.27 |
| tbl_info | 0.17 |
| tbl_user | 0.03 |
| xi_events | 0.20 |
| xi_meta | 2.52 |
| xi_mibs | 0.05 |
| xi_options | 0.05 |
| xi_sysstat | 0.03 |
| xi_users | 0.03 |
Did system update to 5.5.13 followed all directions.
here is the newest profile.zip
benjaminsmith
Hello @jlamar,
Thanks for the new profile. The load has come down significantly since upgrading but the SQL query from above is showing the logentires table is corrupted.
Benjamin
Let's run the following repair command, and then run the query again to see if the table is fixed.| nagios_logentries | NULL |
mysqlcheck -f -r -u root -pnagiosxi --use-frm --all-databases
| nagios_contactnotifications | 3.46 |
| nagios_customvariables | 0.28 |
| nagios_customvariablestatus | 0.30 |
| nagios_eventhandlers | 0.00 |
| nagios_hosts | 0.23 |
| nagios_hoststatus | 0.49 |
| nagios_notifications | 77.55 |
| nagios_objects | 0.80 |
| nagios_serviceescalations | 0.05 |
| nagios_services | 0.88 |
| nagios_servicestatus | 2.15 |
| nagios_statehistory | 85.35 |
| nagios_systemcommands | 0.03 |
| tbl_domain | 0.03 |
| tbl_host | 0.27 |
| tbl_info | 0.17 |
| tbl_user | 0.03 |
| xi_commands | 0.08 |
| xi_events | 0.09 |
| xi_meta | 1.52 |
| xi_mibs | 0.05 |
| xi_options | 0.05 |
| xi_sysstat | 0.03 |
| xi_users | 0.03 |
| tbl_domain | 0.03 |
| tbl_host | 0.27 |
| tbl_info | 0.17 |
| tbl_user | 0.03 |
| xi_events | 0.09 |
| xi_meta | 1.52 |
| xi_mibs | 0.05 |
| xi_options | 0.05 |
| xi_sysstat | 0.03 |
| xi_users | 0.03 |
