apache log type missing from ubuntu 18.04
Re: apache log type missing from ubuntu 18.04
Are you using rsyslog on 192.168.35.11 to send them? Is that system running ubuntu as well? Is it only this machine that has problem? Do others work? Please attach the /etc/rsyslog.conf and any other file in /etc/rsyslog.d from 192.168.35.11.
Yes, 192.168.35.11 is the problematic Ubuntu 18. I have an Ubuntu 16 in this network, thats works correctly, i attached it's screenshot before.
I reconfigured the 35.11 again with the automatic apache script, I attach the config files. Rsyslog will be in the next post, because 3 max...
port 5544 linux files, port 5545 apache files.
Inputs:
Events now:
Let's enable some debug logging to see why it's throwing that parse failure tag:
Edit /etc/init.d/logstash and change line 64 from:
to:
and restart the service with:
Let this run just long enough to allow NLS to process some new Apache logs and then collect the /var/log/logstash/logstash.log file before reverting the config back and restarting the service.
DAEMON_OPTS="agent -f ${LS_CONF_DIR} -l ${LS_LOG_FILE} ${LS_OPTS}"Code: Select all
DAEMON_OPTS="agent -f ${LS_CONF_DIR} -l ${LS_LOG_FILE} ${LS_OPTS} --debug"Code: Select all
systemctl daemon-reload
service logstash restartAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Such lines appear:
{:timestamp=>"2020-04-17T22:20:25.652000+0200", :message=>"output received", :event=>{"message"=>"<133>Apr 17 22:20:19 logoweb_app apache_access: 89.133.xx.xx - - [17/Apr/2020:22:20:09 +0200] \"GET /static/tempP
df/49499/97ren29.pdf HTTP/1.1\" 200 192001 \"http://www.example.hu/?tart=63\" \"Mozilla/5.0 (Linux; Android 9; ANE-LX1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.111 Mobile Safari/537.36\"\n", "@ver
sion"=>"1", "@timestamp"=>"2020-04-17T20:20:25.014Z", "type"=>"apachetest", "host"=>"192.168.35.11", "tags"=>["_grokparsefailure_sysloginput"], "priority"=>0, "severity"=>0, "facility"=>0, "facility_label"=>"ker
nel", "severity_label"=>"Emergency"}, :level=>:debug, :file=>"(eval)", :line=>"365", :method=>"output_func"}Re: apache log type missing from ubuntu 18.04
Does /var/log/syslog contain that <PRI> entry on the beginning of the message? Are you even seeing those apache_access ones in /var/log/syslog?
None of mine contain it, it has to be either rsyslog doing it or apache writing it like that. You said that <PRI> line was NOT in the apache logs, correct?
/var/log/syslog:
Pair of this in /var/log/apache2/access_ssl.log:
Apr 17 22:20:09 logoweb_app apache_access: 89.133.xx.xx - - [17/Apr/2020:22:20:08 +0200] "GET /download/index.php?id=49499 HTTP/1.1" 302 3870 "http://www.example.hu/?tart=63" "Mozilla/5.0 (Linux; Android 9; ANE-L
X1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.111 Mobile Safari/537.36"Code: Select all
89.133.xx.xx - - [17/Apr/2020:22:20:08 +0200] "GET /download/index.php?id=49499 HTTP/1.1" 302 3870 "http://www.example.hu/?tart=63" "Mozilla/5.0 (Linux; Android 9; ANE-LX1) AppleWebKit/537.36 (KHTML, like Gecko)
Chrome/81.0.4044.111 Mobile Safari/537.36"Re: apache log type missing from ubuntu 18.04
Can you PM me the entire logstash.log file?
I sent it on friday.
