If the files are spooling up and not getting processed, you can run the following commands to check that. Again these commands may or may not work depending on your setup.
I would like to tell you that i am not using the PNP.
I am using the Nagios Core.
I have disabled the Perf Data as of now.
Following are the output for the commands:
[xxxxxx@nagiosserver ~]$ ls /usr/local/nagios/share/perfdata/
ls: cannot access /usr/local/nagios/share/perfdata/: No such file or directory
[xxxxxx@nagiosserver ~]$ ls /usr/local/nagios/var/spool/perfdata/ | wc -l
ls: cannot access /usr/local/nagios/var/spool/perfdata/: No such file or directory
0
[xxxxxx@nagiosserver ~]$ ls /usr/local/nagios/var/spool/xidpe/ | wc -l
ls: cannot access /usr/local/nagios/var/spool/xidpe/: No such file or directory
0
