There is no special character in community string its public, but still im getting null message only.
From terminal CLI command its working fine, without any issues.
Regards.
Raj
Plugins for netbackup- Symantec and Tape library quantum
gm_rajkumar
Re: Plugins for netbackup- Symantec and Tape library quantum
So does it run as the nagios user from the command line
su nagios -c "/usr/bin/perl5.8.8 ./check-netapp-ng.pl -H <hostname> -T FAN -w 1 -c 3 -C <community>"-
gm_rajkumar
Scott,
There is no issue on Command line CLI mode its working, please find the results.
OK: FAN 0 | failedfans=0
In xi its not working properly..
Regards,
Raj.
Regards,
Raj.
gm_rajkumar
Scott,
I would like to have an update over this, if you have any other plugin for this(workable) i will try meanwhile.
Regards,
Raj.
Regards,
Raj.
Locking topic as it is also being worked via email support
