NRPE Unable to read output - ON CENTOS7 Server
mccrakem
Re: NRPE Unable to read output - ON CENTOS7 Server
Post by mccrakem »
Hi
[root@dwylbopemail03 ~]# grep nagios /etc/passwd
nagios:x:191:189::/var/spool/nagios:/sbin/nologin
[root@dwylbopemail03 ~]# /usr/lib64/nagios/plugins/check_mail_ratio
CRITICAL - Successful mail delivery ratio 0%
But when I run it from the GUI
DWYLBOPEMAIL03 (CentOS7)
[[email protected] ~]$ /usr/local/nagios/libexec/check_nrpe -H dwylbopemail03.ops-dev.pa-dev.knxa -t 30 -c check_mail_ratio
sh: /bin/sudo: Permission denied
But if I run the same command against DWYLBOPEMAIL01 (RHEL6)
[[email protected] ~]$ /usr/local/nagios/libexec/check_nrpe -H dwylbopemail01.ops-dev.pa-dev.knxa -t 30 -c check_mail_ratio
OK - Successful mail delivery ratio 99%
ssax
Dreams In Code
Post by ssax »
You will need to test like this:
[root@dwylbopemail03 ~]# su -s /bin/bash -c '/bin/sudo /usr/lib64/nagios/plugins/check_mail_ratio' nagios
What does that output?
What is the output of this command?
ls -l /bin/sudo
Please attach the plugin:
mccrakem
Post by mccrakem »
Hi
CRITICAL - Successful mail delivery ratio 0%[root@dwylbopemail03 ~]#
[root@dwylbopemail03 ~]# ls -l /bin/sudo
---s--x--x. 1 root root 143184 Aug 4 2017 /bin/sudo
I have attached the check_mail_ratio file to the ticket
but to be able to upload it I had to add the .txt estension
ssax
Dreams In Code
Post by ssax »
I labbed this up with the same info and directories as yours and it's working. We'll need to debug on a remote.
Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
https://support.nagios.com/tickets/
mccrakem
Post by mccrakem »
Hi Sean
I have also replied within the Ticket
Thanks for your help on this, All is working now, this can be closed
ssax
Dreams In Code
Post by ssax »
Glad to help, locking the thread and marking it as resolved.
