Need help configuring SSL with Nagios XI
tgfde
Re: Need help configuring SSL with Nagios XI
Post by tgfde »
Here's what I'm getting in the log:
[Sun May 20 04:02:12 2012] [notice] Digest: generating secret for digest authentication ...
[Sun May 20 04:02:12 2012] [notice] Digest: done
PHP Warning: Module 'SourceGuardian' already loaded in Unknown on line 0
[Sun May 20 04:02:12 2012] [notice] mod_python: Creating 4 session mutexes based on 256 max processes and 0 max threads.
[Sun May 20 04:02:12 2012] [notice] Apache/2.2.22 (Unix) DAV/2 PHP/5.2.17 mod_python/3.2.8 Python/2.4.3 mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5 mod_perl/2.0.4 Perl/v5.8.8 configured -- resuming normal operations
[Mon May 21 15:29:41 2012] [notice] caught SIGTERM, shutting down
[Mon May 21 15:29:41 2012] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon May 21 15:35:05 2012] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon May 21 15:35:05 2012] [notice] Digest: generating secret for digest authentication ...
[Mon May 21 15:35:05 2012] [notice] Digest: done
[Mon May 21 15:35:05 2012] [notice] mod_python: Creating 4 session mutexes based on 256 max processes and 0 max threads.
[Mon May 21 15:35:05 2012] [notice] Apache/2.2.22 (Unix) DAV/2 PHP/5.2.17 mod_python/3.2.8 Python/2.4.3 mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5 mod_perl/2.0.4 Perl/v5.8.8 configured -- resuming normal operations
[Mon May 21 15:49:05 2012] [notice] caught SIGTERM, shutting down
[Mon May 21 15:49:05 2012] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
tgfde
Post by tgfde »
here's another one from the ssl error log:
Mon May 21 15:29:41 2012] [error] Unable to configure RSA server private key
[Mon May 21 15:29:41 2012] [error] SSL Library Error: 185073780 error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
[Mon May 21 15:35:05 2012] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Mon May 21 15:35:05 2012] [warn] RSA server certificate CommonName (CN) `localhost.localdomain' does NOT match server name!?
[Mon May 21 15:49:05 2012] [warn] RSA server certificate CommonName (CN) `cordmon1' does NOT match server name!?
[Mon May 21 15:49:05 2012] [error] Unable to configure RSA server private key
[Mon May 21 15:49:05 2012] [error] SSL Library Error: 185073780 error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
[Mon May 21 15:55:22 2012] [warn] RSA server certificate CommonName (CN) `cordmon1' does NOT match server name!?
[Mon May 21 15:55:22 2012] [error] Unable to configure RSA server private key
[Mon May 21 15:55:22 2012] [error] SSL Library Error: 185073780 error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
[Mon May 21 15:55:31 2012] [warn] RSA server certificate CommonName (CN) `cordmon1' does NOT match server name!?
[Mon May 21 15:55:31 2012] [error] Unable to configure RSA server private key
[Mon May 21 15:55:31 2012] [error] SSL Library Error: 185073780 error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
[Mon May 21 16:02:50 2012] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Mon May 21 16:02:50 2012] [warn] RSA server certificate CommonName (CN) `localhost.localdomain' does NOT match server name!?
[Mon May 21 16:02:51 2012] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Mon May 21 16:02:51 2012] [warn] RSA server certificate CommonName (CN) `localhost.localdomain' does NOT match server name!?
[Mon May 21 16:17:42 2012] [warn] RSA server certificate CommonName (CN) `cordmon1' does NOT match server name!?
[Mon May 21 16:17:42 2012] [error] Unable to configure RSA server private key
Do you get any errors when you run the following command?
service httpd restart
tgfde
Post by tgfde »
Here's what I get:
[Mon May 21 16:45:48 2012] [warn] RSA server certificate CommonName (CN) `cordmon1' does NOT match server name!?
[Mon May 21 16:45:48 2012] [error] Unable to configure RSA server private key
[Mon May 21 16:45:48 2012] [error] SSL Library Error: 185073780 error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
Have you modified your httpd.conf in the past to specify a ServerName ?
Can you post your /etc/httpd/conf.d/nagiosxi.conf
tgfde
Post by tgfde »
No, I have not modified the http.conf to specify a servername.
<Directory "/usr/local/nagiosxi/html">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
# AuthName "Nagios XI"
# AuthType Basic
# AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
# Require valid-user
</Directory>
Alias /nagiosxi "/usr/local/nagiosxi/html"
Thanks.
I think you might of missed page2 and page 3 of the document....
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
tgfde
Post by tgfde »
I did not perform the steps yet on page 2 because at the end of page 1, it tells you to restart httpd which I did and httpd fails to start. Do I continue on to page 2 even though httpd will not start?
Thanks.
So, to be clear when doing this step
cp ca.crt /etc/pki/tls/certs
cp ca.key /etc/pki/tls/private/ca.key
cp ca.csr /etc/pki/tls/private/ca.csr
You did copy over the same .crt .key .csr files used to make each other? They need to match the info put into them.
tgfde
Post by tgfde »
Yes, I did.
