Error while generating scheduled reports!!
deek
Re: Error while generating scheduled reports!!
Post by deek »
Hi ssax,
So recently we had installed the SSL certificates. probably that might be the issue. Let me try making the changes and get back to you.
-Deek-
Sure, let us know if your issue has been resolved. Thanks!
deek
Post by deek »
Hi Ssax
tailf_logs.txt
changed it to true and restarted httpd service and ran the tail -f command that you provided. Attached the same.
ssax
Dreams In Code
Post by ssax »
Are you still getting the same error after repairing the databases?
Please send me the PDF file so I can inspect it.
PM me a fresh copy of your profile, I'm still seeing http being used (instead of https) in the tail output.
deek
Post by deek »
Hi Ssax
Attached the profile and the sample pdf file.
1592495301-Availability_Report.pdf
profile (1).zip
Deepan.
deek
Post by deek »
Attaching the profile of different nagios instance where the schedule reports are working fine.
profile (2).zip
ssax
Dreams In Code
Post by ssax »
Please attach your /etc/php.ini file.
deek
Post by deek »
php.ini.txt
ssax
Dreams In Code
Post by ssax »
That all looks good, is this system behind a load balancer or a part of an HA setup or anything? Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
https://support.nagios.com/tickets/
