sucessful migration - mysql issues
Re: sucessful migration - mysql issues
selinux is disabled. i beleive this was done by the install.sh XI installation script. i'm sure centos comes out of box with it enabled. It was actually my first thought on the problem.
the service check failure is another one on my list which i've now resolved with your sugestion. seems all our clients only had a 512 length dh key (which wasnt even referenced in nsclient.ini - maybe it's a fallback?) generated a 2048 length key and deployed to our windows hosts which is now working. fwiw now we have a 2048 DH key it doesn't seem to matter about -2 or -3 version enforcement.
Thats the first time i've seen DH key length as the reason for failure - maybe something to add to the 5.7.x release notes?
So thats the Service Alerts failures resolved, however we have ran both active & passive service checks Disabled for testing. it doesnt seem to matter enabled or disabled - CPU time is high and makes XI un-useable.
the new centos8 VM is on the same subnet but different IP so we currently have 2 XI servers running. our standard config allows the entire subnet, for exactly times like this where we're migrating and need both servers available concurrently.
I'll generate a new profile.zip and send it over to you, ssax, so you can see where we currently are... Hope it helps..
There is not profile attached to the PM, please re-attach so I can investigate further.
looks to be something wrong with PM's. resent a PM yesterday with attached file and it was stuck in outbox. retried with a new PM and it's doing the same.
I can PM myself with the file, just cant PM either yourself, @ssax, or @benjaminsmith.
That's normal, it will stay in the outbox until they read it. Profile received, analyzing now. Will update shortly.
Only the mysqld process is showing as consuming the CPU usage, let's check your DB table sizes:
Please send the output of this command (as root):
- NOTE: You may need to adjust the -h 127.0.0.1, the -uroot, and -pnagiosxi in the command if your DB is offloaded to another server and/or you've changed the root mysql password
Please attach your /etc/my.cnf and the output from this command:
Also, I'm seeing this:
You can resolve that by running this command:
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --tableCode: Select all
tail -n100 /var/log/mariadb/mariadb.log /var/log/mysqld.logCode: Select all
[1592307517] NDO-3: ndo_handle_service_status(ndo-handlers.c:953): Unable to execute statement
[1592307537] NDO-3: ndo_return = 1 (Data too long for column 'check_command' at row 1)- NOTE: You may need to adjust the -h 127.0.0.1, the -uroot, and -pnagiosxi in the command if your DB is offloaded to another server and/or you've changed the root mysql password
mysql -h 127.0.0.1 -uroot -pnagiosxi nagios -e "ALTER TABLE nagios_servicestatus MODIFY check_command TEXT NOT NULL DEFAULT '';"Re: sucessful migration - mysql issues
mysql: [Warning] Using a password on the command line interface can be insecure.
| Table | Size in MB |
| nagios_acknowledgements | 0.06 |
| nagios_commands | 0.02 |
| nagios_commenthistory | 455.09 |
| nagios_comments | 6.52 |
| nagios_configfiles | 0.01 |
| nagios_configfilevariables | 0.01 |
| nagios_conninfo | 0.10 |
| nagios_contact_addresses | 0.00 |
| nagios_contact_notificationcommands | 0.01 |
| nagios_contactgroup_members | 0.00 |
| nagios_contactgroups | 0.00 |
| nagios_contactnotificationmethods | 0.13 |
| nagios_contactnotifications | 0.09 |
| nagios_contacts | 0.00 |
| nagios_contactstatus | 0.00 |
| nagios_customvariables | 0.01 |
| nagios_customvariablestatus | 0.01 |
| nagios_dbversion | 0.00 |
| nagios_downtimehistory | 48.19 |
| nagios_eventhandlers | 0.00 |
| nagios_externalcommands | 7.87 |
| nagios_flappinghistory | 0.42 |
| nagios_host_contactgroups | 0.01 |
| nagios_host_contacts | 0.00 |
| nagios_host_parenthosts | 0.01 |
| nagios_hostchecks | 0.09 |
| nagios_hostdependencies | 0.00 |
| nagios_hostescalation_contactgroups | 0.00 |
| nagios_hostescalation_contacts | 0.00 |
| nagios_hostescalations | 0.00 |
| nagios_hostgroup_members | 0.01 |
| nagios_hostgroups | 0.00 |
| nagios_hosts | 0.03 |
| nagios_hoststatus | 0.10 |
| nagios_instances | 0.00 |
| nagios_logentries | 87.62 |
| nagios_notifications | 0.24 |
| nagios_objects | 0.65 |
| nagios_processevents | 0.12 |
| nagios_programstatus | 0.00 |
| nagios_runtimevariables | 0.00 |
| nagios_scheduleddowntime | 4.72 |
| nagios_service_contactgroups | 0.07 |
| nagios_service_contacts | 0.00 |
| nagios_service_parentservices | 0.00 |
| nagios_servicechecks | 0.00 |
| nagios_servicedependencies | 0.00 |
| nagios_serviceescalation_contactgroups | 0.00 |
| nagios_serviceescalation_contacts | 0.00 |
| nagios_serviceescalations | 0.00 |
| nagios_servicegroup_members | 0.03 |
| nagios_servicegroups | 0.00 |
| nagios_services | 0.47 |
| nagios_servicestatus | 0.81 |
| nagios_statehistory | 532.82 |
| nagios_systemcommands | 0.05 |
| nagios_timedeventqueue | 0.00 |
| nagios_timedevents | 0.00 |
| nagios_timeperiod_timeranges | 0.01 |
| nagios_timeperiods | 0.00 |
| tbl_command | 0.04 |
| tbl_contact | 0.01 |
| tbl_contactgroup | 0.01 |
| tbl_contacttemplate | 0.01 |
| tbl_domain | 0.01 |
| tbl_host | 0.02 |
| tbl_hostdependency | 0.01 |
| tbl_hostescalation | 0.00 |
| tbl_hostextinfo | 0.00 |
| tbl_hostgroup | 0.01 |
| tbl_hosttemplate | 0.01 |
| tbl_info | 0.13 |
| tbl_lnkContactToCommandHost | 0.00 |
| tbl_lnkContactToCommandService | 0.00 |
| tbl_lnkContactToContactgroup | 0.00 |
| tbl_lnkContactToContacttemplate | 0.00 |
| tbl_lnkContactToVariabledefinition | 0.00 |
| tbl_lnkContactgroupToContact | 0.00 |
| tbl_lnkContactgroupToContactgroup | 0.00 |
| tbl_lnkContacttemplateToCommandHost | 0.00 |
| tbl_lnkContacttemplateToCommandService | 0.00 |
| tbl_lnkContacttemplateToContactgroup | 0.00 |
| tbl_lnkContacttemplateToContacttemplate | 0.00 |
| tbl_lnkContacttemplateToVariabledefinition | 0.00 |
| tbl_lnkHostToContact | 0.00 |
| tbl_lnkHostToContactgroup | 0.00 |
| tbl_lnkHostToHost | 0.00 |
| tbl_lnkHostToHostgroup | 0.00 |
| tbl_lnkHostToHosttemplate | 0.01 |
| tbl_lnkHostToVariabledefinition | 0.00 |
| tbl_lnkHostdependencyToHost_DH | 0.00 |
| tbl_lnkHostdependencyToHost_H | 0.00 |
| tbl_lnkHostdependencyToHostgroup_DH | 0.00 |
| tbl_lnkHostdependencyToHostgroup_H | 0.00 |
| tbl_lnkHostescalationToContact | 0.00 |
| tbl_lnkHostescalationToContactgroup | 0.00 |
| tbl_lnkHostescalationToHost | 0.00 |
| tbl_lnkHostescalationToHostgroup | 0.00 |
| tbl_lnkHostgroupToHost | 0.01 |
| tbl_lnkHostgroupToHostgroup | 0.00 |
| tbl_lnkHosttemplateToContact | 0.00 |
| tbl_lnkHosttemplateToContactgroup | 0.00 |
| tbl_lnkHosttemplateToHost | 0.00 |
| tbl_lnkHosttemplateToHostgroup | 0.00 |
| tbl_lnkHosttemplateToHosttemplate | 0.00 |
| tbl_lnkHosttemplateToVariabledefinition | 0.00 |
| tbl_lnkServiceToContact | 0.00 |
| tbl_lnkServiceToContactgroup | 0.00 |
| tbl_lnkServiceToHost | 0.01 |
| tbl_lnkServiceToHostgroup | 0.01 |
| tbl_lnkServiceToServicegroup | 0.01 |
| tbl_lnkServiceToServicetemplate | 0.02 |
| tbl_lnkServiceToVariabledefinition | 0.00 |
| tbl_lnkServicedependencyToHost_DH | 0.00 |
| tbl_lnkServicedependencyToHost_H | 0.00 |
| tbl_lnkServicedependencyToHostgroup_DH | 0.00 |
| tbl_lnkServicedependencyToHostgroup_H | 0.00 |
| tbl_lnkServicedependencyToService_DS | 0.00 |
| tbl_lnkServicedependencyToService_S | 0.00 |
| tbl_lnkServicedependencyToServicegroup_DS | 0.02 |
| tbl_lnkServicedependencyToServicegroup_S | 0.02 |
| tbl_lnkServiceescalationToContact | 0.00 |
| tbl_lnkServiceescalationToContactgroup | 0.00 |
| tbl_lnkServiceescalationToHost | 0.00 |
| tbl_lnkServiceescalationToHostgroup | 0.00 |
| tbl_lnkServiceescalationToService | 0.00 |
| tbl_lnkServiceescalationToServicegroup | 0.02 |
| tbl_lnkServicegroupToService | 0.00 |
| tbl_lnkServicegroupToServicegroup | 0.00 |
| tbl_lnkServicetemplateToContact | 0.00 |
| tbl_lnkServicetemplateToContactgroup | 0.00 |
| tbl_lnkServicetemplateToHost | 0.00 |
| tbl_lnkServicetemplateToHostgroup | 0.00 |
| tbl_lnkServicetemplateToServicegroup | 0.00 |
| tbl_lnkServicetemplateToServicetemplate | 0.01 |
| tbl_lnkServicetemplateToVariabledefinition | 0.00 |
| tbl_lnkTimeperiodToTimeperiod | 0.00 |
| tbl_logbook | 0.00 |
| tbl_mainmenu | 0.00 |
| tbl_permission | 0.02 |
| tbl_permission_inactive | 0.02 |
| tbl_service | 0.11 |
| tbl_servicedependency | 0.01 |
| tbl_serviceescalation | 0.00 |
| tbl_serviceextinfo | 0.00 |
| tbl_servicegroup | 0.01 |
| tbl_servicetemplate | 0.02 |
| tbl_session | 0.00 |
| tbl_session_locks | 0.00 |
| tbl_settings | 0.00 |
| tbl_submenu | 0.00 |
| tbl_timedefinition | 0.00 |
| tbl_timeperiod | 0.01 |
| tbl_user | 0.01 |
| tbl_variabledefinition | 0.00 |
| xi_auditlog | 0.78 |
| xi_auth_tokens | 0.03 |
| xi_cmp_ccm_backups | 0.02 |
| xi_cmp_favorites | 0.03 |
| xi_cmp_nagiosbpi_backups | 0.02 |
| xi_cmp_trapdata | 0.03 |
| xi_cmp_trapdata_log | 0.03 |
| xi_commands | 0.00 |
| xi_deploy_agents | 0.02 |
| xi_deploy_jobs | 0.02 |
| xi_eventqueue | 0.64 |
| xi_events | 0.00 |
| xi_incidents | 0.00 |
| xi_meta | 0.02 |
| xi_mibs | 0.05 |
| xi_options | 0.04 |
| xi_sessions | 0.03 |
| xi_sysstat | 0.01 |
| xi_usermeta | 0.13 |
| xi_users | 0.01 |
+--------------------------------------------+------------+Code: Select all
# This group is read both both by the client and the server
# use it for options that affect everything
[client-server]
# include all files from the config directory
!includedir /etc/my.cnf.dthe NDO-3 fix, completes but gets the following error
ERROR 1101 (42000) at line 1: BLOB, TEXT, GEOMETRY or JSON column 'check_command' can't have a default valueRe: sucessful migration - mysql issues
What is the output of these commands?
You may need to do this so set sql_mode to blank:
https://support.nagios.com/kb/article/n ... n-822.html
Try doing this:
Please run these commands from the server and see if it resolves your issue:
Once that's done, apply configuration and see if the problems are resolved.
rpm -qa | grep -i mysql
rpm -qa | grep -i mariadbhttps://support.nagios.com/kb/article/n ... n-822.html
Try doing this:
wget https://assets.nagios.com/downloads/nagiosxi/patches/patch-ndo.sh
sh patch-ndo.shRe: sucessful migration - mysql issues
# rpm -qa | grep -i mysql
php-mysqlnd-7.2.24-1.module_el8.1.0+276+68c728ae.x86_64
mysql-8.0.17-3.module_el8.0.0+181+899d6349.x86_64
mysql-common-8.0.17-3.module_el8.0.0+181+899d6349.x86_64
perl-DBD-MySQL-4.046-3.module_el8.1.0+203+e45423dc.x86_64
mysql-devel-8.0.17-3.module_el8.0.0+181+899d6349.x86_64
mysql-errmsg-8.0.17-3.module_el8.0.0+181+899d6349.x86_64
mysql-server-8.0.17-3.module_el8.0.0+181+899d6349.x86_64
mysql-libs-8.0.17-3.module_el8.0.0+181+899d6349.x86_64Code: Select all
# rpm -qa | grep -i mariadb
mariadb-connector-c-config-3.0.7-1.el8.noarch
mariadb-connector-c-3.0.7-1.el8.x86_64Code: Select all
# mysql -u root -p'nagiosxi' -e "SELECT @@GLOBAL.sql_mode;"
| @@GLOBAL.sql_mode
| ONLY_FULL_GROUP_BY,STRICT_TRANS_TABLES,NO_ZERO_IN_DATE,NO_ZERO_DATE,ERROR_FOR_DIVISION_BY_ZERO,NO_ENGINE_SUBSTITUTION |
+-----------------------------------------------------------------------------------------------------------------------+still the same.
ndo patch output, after the file extraction just incase it might be of use...
...SNIPPED...
UPGRADE: NDO is being upgraded...
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a BSD-compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdlib.h... (cached) yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for string.h... (cached) yes
checking mysql/mysql.h usability... yes
checking mysql/mysql.h presence... yes
checking for mysql/mysql.h... yes
checking mysql/errmsg.h usability... yes
checking mysql/errmsg.h presence... yes
checking for mysql/errmsg.h... yes
checking for GNU libc compatible malloc... yes
/usr/bin/mysql_config
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating include/config.h
*** Configuration summary for ***:
User: nagios
Group: nagios
Bin directory: /usr/local/nagios/bin
Config directory: /usr/local/nagios/etc
Nagios config: /usr/local/nagios/etc/nagios.cfg
Review the options above for accuracy. If they look okay,
type 'make all' to compile NDOUtils, or type 'make' to get
a list of make options.
cd src/ && make ndo.so
make[1]: Entering directory '/tmp/nagiosxi/subcomponents/ndo/ndo-3.0.1.patched/src'
gcc -fPIC -shared -g -O2 -I/usr/include/mysql -m64 ndo.c -o ndo.so -L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -lrt -lssl -lcrypto -ldl -pthread
In file included from ndo.c:143:
ndo-startup.c: In function ‘ndo_startup_thread’:
ndo-startup.c:97:9: warning: implicit declaration of function ‘ndo_deregister_queue_functions’; did you mean ‘ndo_register_queue_callbacks’? [-Wimplicit-function-declaration]
ndo_deregister_queue_functions();
ndo-startup.c:98:9: warning: ‘return’ with no value, in function returning non-void
return;
ndo-startup.c:87:8: note: declared here
void * ndo_startup_thread(void * args)
ndo-startup.c:104:9: warning: ‘return’ with no value, in function returning non-void
return;
ndo-startup.c:109:9: warning: ‘return’ with no value, in function returning non-void
return;
ndo.c: In function ‘ndo_log’:
ndo.c:153:5: warning: implicit declaration of function ‘asprintf’; did you mean ‘vsprintf’? [-Wimplicit-function-declaration]
asprintf(&tmp, "NDO-3: %s", buffer);
vsprintf
make[1]: Leaving directory '/tmp/nagiosxi/subcomponents/ndo/ndo-3.0.1.patched/src'
make[1]: 'ndo.so' is up to date.
/usr/bin/install -c -m 774 -o nagios -g nagios src/ndo.so /usr/local/nagios/bin/ndo.so
Shared module ndo.so installed
/usr/local/nagios/etc/nagios.cfg configured to use NDO
UPGRADE: POST-UPGRADE: NDO post upgrade started...
Performing upgrade...
> Updating dbversion table
Database upgrade is complete!
UPGRADE: POST-UPGRADE: NDO post upgraded OK.
UPGRADE: NDO upgraded OK.edit: ndo2db.service does not exist on my install. is it mean to?
The ndo2db service no longer exists in XI 5.7 (on purpose).
Did you restart the nagios services after making those changes? If not, please do.
Please send me a FRESH copy of your profile so I can view the latest logs, you can download it from Admin > System Profile > Download Profile button.
Hi ssax,
nagios service was restarted just before i posted my last message. VM was also rebooted.
another profile.zip has been sent to you.
thanks!
thanks!
