AWS - Nagios Log Server
Re: AWS - Nagios Log Server
I just tested this launching the below image
At 13 minutes it had restarted and was ready to use and configure through the web UI at the Public IP
You aren't launching this into a location that doesn't have Internet access are you?
mneubauer
Post by mneubauer »
scottwilkerson wrote:I just tested this launching the below image
Internet access is fine. Do I need all of those custom TCP ports added to my security group?
mneubauer
Post by mneubauer »
mneubauer wrote:
scottwilkerson wrote:I just testes this launching the below image
I tried adding the TCP ports that you have but that didn't work either. I have a t2.micro instance. Do you think that could be the problem?
mneubauer wrote:I have a t2.micro instance. Do you think that could be the problem?
Log Server will not run on a t2.micro, for sure, I don't know if that is the only problem, but it cannot run with that little memory.
mneubauer
Post by mneubauer »
I built a brand new instance using a t3.medium which meets the min specs and I'm still getting the error - Unit httpd.service could not be found.
Is there anything else that I can check on?
Can you show the output of the following
grep rc.local /var/log/messages
mneubauer
Post by mneubauer »
scottwilkerson wrote:Can you show the output of the following
Yep here it is.Thanks
[centos@ip-172-31-1-158 ~]$ sudo grep rc.local /var/log/messages
Jun 17 14:08:51 ip-172-31-1-158 systemd: Starting /etc/rc.d/rc.local Compatibili ty...
Jun 17 14:08:51 ip-172-31-1-158 rc.local: % Total % Received % Xferd Average Speed Time Time Time Current
Jun 17 14:08:51 ip-172-31-1-158 rc.local: Dload Upload Total Spent Left Speed
Jun 17 14:10:58 ip-172-31-1-158 rc.local: 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:04 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:06 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:07 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:08 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:09 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:10 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:11 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:12 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:13 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:14 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:15 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:16 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:17 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:18 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:19 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:20 --:--:-- 0#0 15 0 0 0 0 0 0 0 0 --:--:-- 0:00:21 --:--:-- 0 #015 0 0 0 0 0 0 0 0 --:--:-- 0:00:22 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:23 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:24 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:25 --:--: -- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:26 --:- -:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:27 -- :--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:28 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:2 9 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00 :30 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0: 00:31 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:32 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:33 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--: -- 0:00:34 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:- -:-- 0:00:35 --:--:-- 0#015 0 0 0 0 0 0 0 0 -- :--:-- 0:00:36 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:37 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:38 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:39 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:40 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:41 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:42 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:43 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:44 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:45 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:46 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:47 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:48 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:49 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:50 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:51 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:52 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:53 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:54 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:55 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:56 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:57 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:58 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:00:59 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:00 --:--:-- 0#0 15 0 0 0 0 0 0 0 0 --:--:-- 0:01:01 --:--:-- 0 #015 0 0 0 0 0 0 0 0 --:--:-- 0:01:02 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:03 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:04 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:05 --:--: -- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:06 --:- -:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:07 -- :--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:08 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:0 9 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01 :10 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0: 01:11 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:12 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:13 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--: -- 0:01:14 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:- -:-- 0:01:15 --:--:-- 0#015 0 0 0 0 0 0 0 0 -- :--:-- 0:01:16 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:17 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:18 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:19 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:20 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:21 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:22 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:23 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:24 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:25 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:26 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:27 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:28 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:29 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:30 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:31 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:32 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:33 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:34 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:35 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:36 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:01:37 --:--:-- 0#015 0 0 0 0 0 0 0 0 --:--:-- 0:0
Jun 17 14:10:58 ip-172-31-1-158 systemd: Started /etc/rc.d/rc.local Compatibility.
something doesn't seem correct as this should have launched a much larger process
Can you run the following
sudo su
curl https://assets.nagios.com/downloads/nagiosxi/installNagiosXIvm_el7_ami.sh | sh
mneubauer
Post by mneubauer »
scottwilkerson wrote:something doesn't seem correct as this should have launched a much larger process
sudo su
[root@ip-172-31-1-158 centos]# curl https://assets.nagios.com/downloads/nag ... el7_ami.sh | sh
0 0 0 0 0 0 0 0 --:--:-- 0:02:07 --:--:-- 0curl: (7) Failed to connect to 2600:3c00::f03c:91ff:fedf:b821: Network is unreachable
Somehow you must be launching this in an environment or selecting a VPC with special routing that has IPv6 enabled but cannot route to the address provided by DNS.
One possible workaround for this host would be to run the following:
echo "72.14.181.71 assets.nagios.com" >> /etc/hosts
but I suspect you are going to hit other barriers for the same issue as the install progresses
