Apache problem
benningtonr
Re: Apache problem
Post by benningtonr »
Ok, perfect, i have only one thing remaining,
Memory Usage Warning 21h 21m 12s 5/5 2012-05-25 08:17:06 WARNING - 1458 / 2002 MB (%) Free Memory, Used: 544 MB, Shared: 0 MB, Buffers: 35 MB, Cached: 413 MB
This is a new install, with nothing but Apache running, no web site are set up bone stock. in the VM I gave it 2g ram.
Any ideas as to why it is warning?
Thanks again for all the help
Re: Apache problem
Can you give me the command this is using from Configure -> CCM -> Services -> Modify
benningtonr
Re: Apache problem
here you go, thank you for your time
Re: Apache problem
I think we need to install one more thing
sudo apt-get install bc
benningtonr
Re: Apache problem
on ubuntu or nagios server
Re: Apache problem
Ubuntu
benningtonr
Re: Apache problem
it was already on there
ronb@ubuntu:/$ sudo apt-get install bc
[sudo] password for ronb:
Reading package lists... Done
Building dependency tree
Reading state information... Done
bc is already the newest version.
bc set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
ronb@ubuntu:/$
Re: Apache problem
Sorry, on other Linux systems dc is part of bc package...
Run
sudo apt-get install dc
