Nagios Logging - System Jobs under Command Subsystem
nguyenhung12345
Re: Nagios Logging - System Jobs under Command Subsystem
Post by nguyenhung12345 »
cdienger wrote:When was the move done? The message was logged on the 13th.
What is the output of the "df -h" command on each machine?
Yes, I moved it on 13 July, 2020.
This is results what we run from each nodes & cluster:
Cluster:
sysadm@epselog01:~$ df -h
udev 16G 0 16G 0% /dev
tmpfs 3.2G 1.1M 3.2G 1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv 1.5T 1.2T 256G 83% /
tmpfs 16G 0 16G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/loop0 97M 97M 0 100% /snap/core/9436
/dev/sda2 976M 280M 630M 31% /boot
//10.99.100.132/snapshot_repos 875G 375G 501G 43% /mnt/snapshot_repos
/dev/loop2 97M 97M 0 100% /snap/core/9665
tmpfs 3.2G 0 3.2G 0% /run/user/1000
Nodes:
Node1:
administrator@EPVNLOG01:~$ df -h
udev 3,9G 0 3,9G 0% /dev
tmpfs 795M 1,3M 794M 1% /run
/dev/sda1 492G 434G 38G 93% /
tmpfs 3,9G 0 3,9G 0% /dev/shm
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup
/dev/loop1 55M 55M 0 100% /snap/core18/1754
/dev/loop0 256M 256M 0 100% /snap/gnome-3-34-1804/36
/dev/loop2 2,3M 2,3M 0 100% /snap/gnome-system-monitor/148
/dev/loop6 1,0M 1,0M 0 100% /snap/gnome-logs/93
/dev/loop5 2,3M 2,3M 0 100% /snap/gnome-system-monitor/145
/dev/loop4 384K 384K 0 100% /snap/gnome-characters/539
/dev/loop3 384K 384K 0 100% /snap/gnome-characters/550
/dev/loop8 63M 63M 0 100% /snap/gtk-common-themes/1506
/dev/loop9 161M 161M 0 100% /snap/gnome-3-28-1804/116
/dev/loop7 256M 256M 0 100% /snap/gnome-3-34-1804/33
/dev/loop11 1,0M 1,0M 0 100% /snap/gnome-logs/100
/dev/loop15 162M 162M 0 100% /snap/gnome-3-28-1804/128
/dev/loop13 97M 97M 0 100% /snap/core/9436
/dev/loop14 55M 55M 0 100% /snap/gtk-common-themes/1502
tmpfs 795M 16K 795M 1% /run/user/121
/dev/loop16 55M 55M 0 100% /snap/core18/1880
/dev/loop10 97M 97M 0 100% /snap/core/9665
tmpfs 795M 0 795M 0% /run/user/1000
Node2:
it@epdelog01:~$ df -h
udev 3.9G 0 3.9G 0% /dev
tmpfs 794M 872K 793M 1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv 195G 166G 21G 89% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/loop1 97M 97M 0 100% /snap/core/9436
/dev/sda2 976M 146M 764M 16% /boot
/dev/sda1 511M 6.1M 505M 2% /boot/efi
tmpfs 794M 0 794M 0% /run/user/1000
Node3:
it@epuslog01:~$ df -h
/dev/sda2 1007G 860G 97G 90% /
If ticket is opening long, you can close it. Please follow up me by email if needed ([email protected])
Closing thread as this is also being worked in a ticket
