Cannot Apply System Configuration
Re: Cannot Apply System Configuration
Can you run the following and post /tmp/perms.txt
ls -lR /usr/local/nagios/etc > /tmp/perms.txt
mccrakem
Post by mccrakem »
here is the output or perms.txt
This is really bizarre, the permissions look correct but trying to discover why you are getting the Cannot open/overwrite service configuration files (check the permissions)! error
If you go to the CCM -> Services
Sort by the "Status" column
do you see any items that are marked "Not Applied"?
Also, if you sort by the "Config Name" column, are there any that are blank?
mccrakem
Post by mccrakem »
Under Status I have 1 service that is not applied
[u'dummy1.server.com' CPU Stats Yes Not Applied
Under Config Name there is nothing blank, everything has a config name
I have deleted the service that was not applied [u'dummy1.server.com
and i have reran the reconfigure_nagios,.sh script
Warning: Host 'www.skillsportal.com' has no default contacts or contactgroups defined!
Checked 292 hosts.
Checked 63 host groups.
Checked 2 service groups.
Checked 94 contacts.
Checked 5 contact groups.
Checked 157 commands.
Checked 42 time periods.
Checked 0 host escalations.
Checked 292 hosts
Checked 0 host dependencies
Checked 42 timeperiods
Checking misc settings...
Total Warnings: 158
Total Errors: 0
> Return Code: 0
While the script was running I thought I should have checked under hosts before starting it
I noticed 1 host had nothing (blank) for the config name
Should I have delete this and rerun the script again, but looks like it has run successfully
mccrakem
Post by mccrakem »
I have just deleted that blank Host and reran the config
Completed successfully again
Thanks Scott
mccrakem wrote:I have just deleted that blank Host and reran the config
Thanks Scott
Great!
glad to hear it is resolved
Locking thread
