ORA errors monitoring
RIDS_I2MP
Re: ORA errors monitoring
Post by RIDS_I2MP »
We checked the plugin suggested by you. Also, we checked few other logs related plugins as well but all of them giving same error as below:
Log check error: Log file C:\\app\\oracle\\diag\\rdbms\\xposprm\\xposprm\\trace\\alert_xposprm does not exist!
Below are the details:
We are using NCPA agent and want to monitor text file generated in Windows C drive.
C:\app\oracle\diag\rdbms\xposprm\xposprm\trace (location)
alert_xposprm.txt -- filename
10.15.0.15 - server
Please help us with the command.
Thanks & Regards,
I2MP Team.
jbrunkow
Post by jbrunkow »
Could it be that the nagios user that is looking for the file does not have permissions to see it? Please try another user in the command or elevate the nagios user's permissions for that file.
RIDS_I2MP
Post by RIDS_I2MP »
We changed the permission as well, but still same error.
I really feel I should go with some other plugin. Could you please suggest here.
Is it possible for you to take remote session and try helping us out?
Thanks & Regards,
I2MP Team.
jbrunkow
Post by jbrunkow »
Let's transition this issue to a ticket. That will allow us to establish a remote session so that we can bring this to a more swift resolution.
To open a support ticket:
https://support.nagios.com/tickets/
Others have had success with check_logfiles and check_log, so I thought those plugins might work well for you too. Maybe this works differently on an Oracle machine.
RIDS_I2MP
Post by RIDS_I2MP »
Ticket#288209 has been raised.
Thanks & Regards,
I2MP Team.
RIDS_I2MP wrote:Hello,
Closing thread
