Hi
Are you sure your backup is not corrupted?
No I am not sure but I have used 3 different backups.
The backup file is approx 5.7GB
Is there a way to test the backup before I do a restore to see if it is ok ?
Can you find the nagiosxi db in the backup tarball?
If I extract the .tar.gz file on a Windows Server I can see the following
The folder pgsql has a file called nagiosxi.sql but it is only 4.8MB
The folder mysql has a file called nagios.sql it is 993MB
The folder mysql has a file called nagiossql.sql it is 2.60MB
Is it in postgres or mysql?
Looks like its in mysql
Restore of database - Database error
Re: Restore of database - Database error
You can always test the backup on the "old" server. Just run add a new host or a service, then restore from the backup to see if the newly added object would be gone. If everything works well on the old server, this would mean that there is a problem with the new server or/and the restore script.Is there a way to test the backup before I do a restore to see if it is ok ?
This means the nagiosxi db is in postgres, not mysql.The folder pgsql has a file called nagiosxi.sql but it is only 4.8MB
At this point, I would recommend that you open a support ticket via our support center here:
https://support.nagios.com/tickets/
We may need to schedule a remote session in order to further troubleshoot the issue.
Hi
I am actually starting 2 weeks of vacation starting this evening, I was hoping that this was going to be something simple to resolve
Can I leave this open and then when I get back on the 24th Aug I can raise the support ticket and hopefully get this database moved to the new system
Sounds goodmccrakem wrote:Hi
Locking thread, ticket received, we will continue support through the ticket.
